Been having intermittent problem with tranny shifting into top gear. thought it was a ground problem but still happens. Driving at 65mph and car decides to shift down a gear. Won't shift back up for 2 miles. Then decides to shift up and be fine rest of way to work.
First time it happened I pulled over and shut he car off and it would crank but didn't want to start. Wiggled the ground loop on the top of the supercharger by the front left bolt and it was loose. After wiggling the car started and shifted top gear. Cleaned ground and even added a ground wire from here to body. Worked for a week until tonight on the way to work.
