Thread: no speedo no shifting after motor swap
Results 1 to 5 of 5
  1. #1 no speedo no shifting after motor swap
    Sep 2012
    iowa
    Put a new engine in my 99 gt and now it wont shift and I have no speedometer. Replaced the VSS and still nothingput volt meter on the plug to the VSS and it reads .2-.17V. I'm to understand that this should be reading almost 5V with ignition on. Every other sensor reads 5-12v when checked. I traced the VSS lead all the way back to the PCM and have nothing coming out of it. Any suggestions or ideas would be greatly appreciated. Thanks
  2. #2 Re: no speedo no shifting after motor swap
    Omaha, NE
    Throwing any codes?
  3. #3 Re: no speedo no shifting after motor swap
    Sep 2012
    iowa
    We put our scanner on but its throwing no codes.
  4. #4 Re: no speedo no shifting after motor swap
    Check the grounds at the front transmission stud. The +5V is likely spliced up on the engine harness from the various sensor power etc. And double check the wiring that comes over the valve cover by the PS pump down to the VSS. It may have gotten burned on the manifold.
  5. #5 Re: no speedo no shifting after motor swap
    Sep 2012
    iowa
    No burnt wires and grounds seem to be A OK. any other suggestions?
  1. Motor swap
    By Pontiac Man in forum General Grand Prix Discussion
    Last Post: 02-26-2012, 10:27 PM
  2. Fuel gauge dosnt work after wireing harness swap and motor swap
    By guimond47 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-02-2011, 06:01 PM
  3. erratic speedo/shifting
    By macey43 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-20-2011, 04:44 PM
  4. Motor swap
    By redgp89 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-28-2009, 01:00 AM
