Thread: I guess a newb question about trans fluid
Results 1 to 14 of 14
  1. #1 Re: I guess a newb question about trans fluid
    GTP Level Member Scimmia's Avatar
    QCA, IA
    GM started using Dex VI in 2006 model year cars; before that, they used Dexron III. If you want to convert pre-06 cars to Dex VI completely, you would need to take your car to someone who can do a completely fluid exchange. Otherwise, you can drop the pan, which will get ~60% of the fluid out, and refill with Dex VI. After a couple of times you've got mostly Dex VI. I do a pan drop every 30K mi.
    2001 Buick Regal LS - Almost Stock
  2. #2 Re: I guess a newb question about trans fluid
    Ohio
    yet mixing dexron VI and dexron III is not going to hurt anything vause i figured id just drop the pan and i know you cant get the fluid out of the torque convertor by just droping the pan so i donno
  1. Grand Prix newb with a start off question
    By PontiacBoy13 in forum Introductions/Noob Questions
    Last Post: 08-24-2008, 08:16 PM
  2. Who can guess what happens next?
    Last Post: 07-09-2008, 02:44 PM
  3. trans fluid level
    By fst in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-13-2008, 02:45 PM
  4. New Mod, guess what its for.
    By GR8racingfool in forum Visual/Body Modifications
    Last Post: 05-07-2008, 08:56 AM
  5. Recommended Trans Fluid
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 03-20-2008, 05:57 PM
