Thread: Tci transmission controller unit?
Results 1 to 3 of 3
  1. #1 Tci transmission controller unit?
    SE Level Member 2000gtpbt's Avatar
    Mar 2012
    Alexandria, MN
    I was reading a 2006 Hot Rod magazine and after reading about then rebuilding a 305 small block I saw a ad for Tci transmission. It had a list of transmissions it works with and the 4t65e was there but when you go to the site now it's not any where. I found the unit even tho it's not on there would it still work? Dose any one have this? One transmission they list is the 4l60e witch has the same connector as the 4t65e, here's the link.
    EZ TCU - Electronic Automatic Transmission Controller - TCI® Auto
    Any man who can drive safely while kissing a pretty girl is simply not giving the kiss the attention it deserves.
    Albert Einstein
  2. #2 Re: Tci transmission controller unit?
    Omaha, NE
    This would be great for a vehicle not controlled by a pcm, such as a dune buggy, go kart, etc.
  3. #3 Re: Tci transmission controller unit?
    Mar 2012
    Alexandria, MN
    Yeah it would, I was thing it's a electronic controlled transmission you could set the shift points if you changed the gears.
    Albert Einstein
  1. Defrosting controller
    By bpeters21 in forum General Tech Discussion
    Last Post: 10-08-2011, 05:28 PM
  2. Boost Controller
    By tazyboy28 in forum Off Topic Discussion
    Last Post: 12-21-2009, 07:55 PM
  3. Boost controller
    By selliott in forum Turbo
    Last Post: 10-19-2009, 05:07 PM
  4. Boost Controller?
    By RicerKiller in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-08-2009, 07:23 PM
