Thread: Gear selector lever popping off on 4t65
Results 1 to 11 of 11
  1. #1 Gear selector lever popping off on 4t65
    GTP Level Member buickman104's Avatar
    NYC
    On my 2000 GTP with 199k miles the gear selector arm that is connected to the shifter inside my vehicle keeps popping off. When I push it back in it feels loose. I believe that I need to replace the arm/lever. Is there a right up for it? Or can someone give me pointers. Also Anyone have the part number? I looked it up on rock auto and the description was vague with no pictures.
    Here is a picture
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  2. #2 Re: Gear selector lever popping off on 4t65
    Denver
    If I were you I would MacGyver it by taking off the arm, drilling and tapping a small hole, and putting a retaining screw with washer in the stud.
    Otherwise, you're looking at most likely a dealer or JY part.
  3. #3 Re: Gear selector lever popping off on 4t65
    Antonio...interior or externior cable keeps coming off?
    Exterior..let's blame Max, I think he was around during the install. More likely you need a new cable as the plastic on some comes off easier than others.
  4. #4 Re: Gear selector lever popping off on 4t65
    NYC
    Looks that way Bill, Do you have any idea where I can get one? The thing keeps popping off more often now and it sucks with all the parallel parking that I need to do in the city.
  5. #5 Re: Gear selector lever popping off on 4t65
    I asked a multiple choice question.
  6. #6 Re: Gear selector lever popping off on 4t65
    NYC
    The exterior loop that goes around the nipple is what has worn down and keep popping off. The rest of the assembly is fine.
  7. #7 Re: Gear selector lever popping off on 4t65
    New cable.. JY time.
  8. #8 Re: Gear selector lever popping off on 4t65
    NYC
    Bill, how hard is it to replace? Considering how far junk yards are from me i might just Macguyver it for now. Will the range selector arm come out with losening out that big bolt on it ?
  9. #9 Re: Gear selector lever popping off on 4t65
    Denver
    the other thing you could do is replace the stud and socket with soemthing new like this:
    McMaster-Carr
  10. #10 Re: Gear selector lever popping off on 4t65
    NYC
    Since I have no junkyard close to me or a garage to figure out how the linkage works I just zip tied them together for now. Hoping it holds for a while.
  11. #11 Re: Gear selector lever popping off on 4t65
    that 15 on top will let the arm come free with some wiggle time.
  1. Problems with gear selector switch
    By Jordanmccarty in forum General Tech Discussion
    Last Post: 03-02-2012, 07:24 PM
  2. Gear selector lights
    By Freimuth in forum General Tech Discussion
    Last Post: 09-15-2011, 09:13 AM
  3. Gear shift lever hard to operate
    By jokyfo in forum General Tech Discussion
    Last Post: 10-11-2010, 04:48 PM
  4. shift selector lever very stiff
    By almighty in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-19-2009, 05:18 PM
  5. Gear selector is a gear off after rebuild
    By skalor in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-17-2008, 11:08 PM
