Thread: Heat and the 4t65E
Results 1 to 10 of 10
  1. #1 Heat and the 4t65E
    Jul 2012
    West Virginia
    OK, so if you have been following my other thread on the rebuild, you know there are problems. Here is a rundown:
    Cold engine and tranny: Everything is fine, runs like a top.
    Engine and tranny at operating temp: Engine runs fine. Tranny slips, mis-shifts (both under load) and sometimes sets 0742. Also occasionally bangs into gear if gas pedal is tramped while struggling under load (ie...going uphill). Sometimes downshifts, only to upshift then drop out of gear then downshift again. At highway speed (65mph) will seem to run fine until a hill or dropping out of the gas at which time the engine will rev with no forward power. If allowed to slow to 45mph it will go into gear and proceed just fine.
    I am now noticing a browning of the fluid and a slight burned smell (obviously from the slipping/mis-shifting). Something is very wrong here.
    Vital info:
    Fluid: Dexron/Mercon
    Brand New: MAF, TPS, MAP sensors
    What, in the tranny, is affected by heat that could cause this type of activity?
  2. #2 Re: Heat and the 4t65E
    Apr 2009
    Fort Worth TX
    You said the TCC apply valve looked good and you replaced the TCC solenoid, right?
    I think it's definitely something in the VB.
  3. #3 Re: Heat and the 4t65E
    Jul 2012
    West Virginia
    Yeah, TCC apply valve looked fine, no scoring at all. All solenoids as well as the TC are new.
  4. #4 Re: Heat and the 4t65E
    Apr 2009
    Fort Worth TX
    Please refresh everyone's memory.
    What were the symptoms that lead you to rebuilding the transmission in the first place?
  5. #5 Re: Heat and the 4t65E
    Jul 2012
    West Virginia
    The original problem was bang shifting. Then it started hesitating between 1-2 really bad. There at the end, it wouldn't go into second at all.
  6. #6 Re: Heat and the 4t65E
    Apr 2009
    Fort Worth TX
    Did you replace the channel plate or reuse the original?
  7. #7 Re: Heat and the 4t65E
    Jul 2012
    West Virginia
    I reused the original channel plate, but did replace the gaskets. Umm, I'm probably grasping at straws here, but the parking brake wouldn't have any affect on tranny operation would it? I only ask because on day one of the tranny removal, I went to set the parking brake and the damn bracket that holds the cables across the back frame member broke in half. The parking brake pedal went to the floor, but I got it back up. The brake is not dragging and the brake light is out.
  8. #8 Re: Heat and the 4t65E
    Apr 2009
    Fort Worth TX
    The channel plates are prone to widening/wear of the check ball holes. A ball can get lodged in a hole and cause all kinds of problems. Did you make sure the holes were much smaller than the check balls?
  9. #9 Re: Heat and the 4t65E
    Jul 2012
    West Virginia
    I had never heard or read about that. I did not check the size of the check-ball holes. However, thinking back on it, I didn't notice anything that appeared out of the ordinary when I checked the channel plate and I didn't notice any of the check-balls seating "too deep".
  10. #10 Re: Heat and the 4t65E
    Apr 2009
    Fort Worth TX
    I not being an expert can only guess it's something with the valve body after getting up to temperature.
    Maybe trannyman could help. I would try posting this in the TEP forum.
  1. Tranny Swap 4T65E-HD to 4t65E
    By windowrattler in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-27-2012, 03:47 PM
  2. 4t65e to 4t65e-hd swap
    By kc199 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-22-2011, 04:11 PM
  3. 4t65E replacing 4t65e-hd question
    By guitarguyucf in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-29-2010, 10:33 PM
  4. No Heat!
    By srspicer in forum General Tech Discussion
    Last Post: 10-25-2009, 11:55 PM
  5. "97" 4t65e-hd succesfully installed replacing the "00" 4t65e-hd
    By mikedinthecity in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-06-2009, 01:42 PM
