Thread: Torque converter, is my one-way stator clutch gone?
Results 1 to 5 of 5
  1. #1 Torque converter, is my one-way stator clutch gone?
    Feb 2008
    San Diego, CA
    FLHB torque converter from my 4T65E
    From what I understand of how a torque converter works, the one-way clutch in the stator should allow it to rotate freely in one direction (clockwise), but not rotate in the other (counterclockwise). Right?
    See video:
    MOV032.mp4 video by agrazela - Photobucket
    I can rotate the stator freely in either direction. So is the one-way clutch gone?
  2. #2 Re: Torque converter, is my one-way stator clutch gone?
    Denver
    I have my TC dropped and in my garage, I will check and confirm.
    I'm pretty sure you're not correct.
    The TC is nothing more than a fluid coupling where the stator fins INDUCE rotation in the rotor fins. This induction is done via the ATF and the bernoulli effect.
    Take two regular household fans. Aim them toward one another and place them about 2" apart. Turn one on, it will cause the oher one to rotate as the air induces rotation. This is all a TC is, except it's submerged in ATF.
  3. #3 Re: Torque converter, is my one-way stator clutch gone?
    HUDSON
    I Watched your video
    The splines you are turning are the stator splines that engage the stator support on the front of the transmission, the stator support "holds" the stator so the sprag can function. With the converter out of the transmission, it (stator) is just sitting in the converter, and yes you will be able to turn it both ways, nothing to worry about.
  4. #4 Re: Torque converter, is my one-way stator clutch gone?
    Andrew...you can always spin a converter either way. Have a couple on the floor if you'd like to see verification. You absolutely should be able to do what you are doing.
    PS.. HI Buddy!
    FLHB (still have the LeSabre I see)
  5. #5 Re: Torque converter, is my one-way stator clutch gone?
    Feb 2008
    San Diego, CA
    Bill, yes I do still have the LeSob. I need some parts, sending PM and posting in the "need parts" section(s).
  1. torque converter clutch (tcc) help.
    By selym17 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-08-2012, 01:43 PM
  2. Torque converter clutch
    By Teddyb in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-09-2012, 08:38 PM
  3. Torque Converter
    By fri3dchick3n in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-28-2012, 06:43 AM
  4. Torque converter clutch engages...boost climbs with throttle
    By xxmattfxx in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-21-2011, 08:51 AM
  5. Bad converter clutch??
    By skalor in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-08-2010, 10:29 AM
