Thread: Transgo Shift Kit, 1st to 2nd Slower Then Stock? Help!
Results 1 to 7 of 7
  1. #1 Re: Transgo Shift Kit, 1st to 2nd Slower Then Stock? Help!
    Houston
    I've heard positives and negatives from all of them. The only negative I hear about Will (overkill) is communication and the time it takes to get the PCM.
  2. #2 Re: Transgo Shift Kit, 1st to 2nd Slower Then Stock? Help!
    SE Level Member HiLuckyB's Avatar
    Romulus, MI
    Overkill seems to be from Canada, So I can see it taking longer to get it.
    1998 GT Coupe
    MODS- Overkill Tune- ZZP 3" 304SS Catless Downpipe- Transgo Shift Kit- 180 T-Stat- Taylor 8mm Wires- Ebay Air Intake- Flipped Motor Mounts
    Ordered- Desert Fox Transmission Cooler
  1. Installing Transgo SK4T65E shift kit - need help with valve body removal (side case)
    By Overboost in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-31-2012, 04:54 PM
  2. transgo shift kit install Q
    By GTPJOE90 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-10-2012, 11:19 AM
  3. Just Ordered Transmission Cooler and TRANSGO Shift Kit (UPDATED!)
    By lattyd in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-09-2012, 11:40 AM
  4. stock gt 0-60 slower then normal?
    By dkitt10 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-02-2011, 03:15 PM
  5. Thrasher vs Transgo shift kit
    By anks106 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-03-2008, 10:21 PM
