Thread: 04 GTP Comp G Shifting Hard from 1st to second gear
Results 1 to 2 of 2
  1. #1 04 GTP Comp G Shifting Hard from 1st to second gear
    SE Level Member 850Fishing's Avatar
    Jan 2012
    Florida
    My friend has an 04 grand prix gtp thats shifting hard from first to second gear, seems like its slipping sometime and dosent want to shift. He has flushed and replaced the trans fluid and filter with no change in issues.
    Vehicle background: All stock, 109,906 milage
    Will post scan logs and tune soon
  2. #2 Re: 04 GTP Comp G Shifting Hard from 1st to second gear
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    Sometimes a hard shift is result of excessive slippage and the accumulator maxes out and then all the sudden it is full on pressure to apply the clutch. 2nd is known for this as it has very loose factory clearance and there is a long delay for the shift to complete. Add in high mileage and overall wear and the problem gets worse. The best and really only way to see what is really happening is to have the car diagnosed with a scan tool and watch the 1-2 shift time and commanded pressure. There are other reasons to have a harsh 1-2 shift but this is one that is more common to see. Broken accumulator springs, stuck valves in valve body, etc can also cause harsh shifts.
  1. Shifting hard
    By zildjian102 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-25-2011, 08:25 PM
  2. shifting hard
    By jaredbos 1 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-16-2011, 12:25 AM
  3. Maybe shifting too hard?
    By Claude in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-27-2010, 08:31 PM
  4. Help again with trans shifting a bit hard
    By ajm786 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-22-2009, 08:27 PM
  5. Hard shifting
    By Seagya in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-12-2009, 09:50 AM
