Thread: Part (thin, flat metal) that falls out when changing trans filter
Results 1 to 4 of 4
  1. #1 Part (thin, flat metal) that falls out when changing trans filter
    Jun 2012
    Florida
    I know I've read about this before, so I'll apologize for the repeat post, but I'm wondering what happens if the little flat metal piece that should have stayed in the transmission isn't replaced in the proper position. I really don't want to drop the pan again to double check, as I wasn't sure how it was supposed to go, and I can't remember how I ended up replacing it. I now understand that the "V" should go up. My transmisssion works well enough (134,000 miles, don't know if it has ever been replaced), but it is slow to shift into fourth (overdrive), waiting until 44-45 mph. Strangely, if I engage the cruise control, it shifts into overdrive at slower speeds.
    What, exactly does the thin metal piece with the V actually do? I know it redirects fluid at certain temperatures, but why? Also, could my trans be damaged by operation with the piece incorrectly installed? Any true transmission gurus out there?
  2. #2 Re: Part (thin, flat metal) that falls out when changing trans filter
    It's called the thermistor or something like that.
    http://www.grandprixforums.net/trans...nks-42428.html
  3. #3 Re: Part (thin, flat metal) that falls out when changing trans filter
    Pennsylvania
    Based on what I've read, Thermistors are temperature sensing devices that, the electrical resistance of the metal decreases as the temp increases, so it can be used to detect temp in that way based on how much current the pcm sees from it... maybe it's part of the transmission's fluid temp sensor?
    Sport Edition Kv5 18x8
  4. #4 Re: Part (thin, flat metal) that falls out when changing trans filter
    St. Louis
    44-45 is where mine always wants to pickup overdrive. See nothing wrong there. About the only thing I've noticed is that when the car is cold (first drive in the am) it won't lock the converter until it warms up to a certain point.
  1. changing fluid and filter in tranny???
    By blowfishRus6 in forum General Tech Discussion
    Last Post: 07-23-2012, 06:06 AM
  2. Changing that oil filter. I need tips
    By Z28 in forum General Tech Discussion
    Last Post: 01-10-2011, 01:13 PM
  3. changing trans fluid
    By smoka stang in forum General Tech Discussion
    Last Post: 08-16-2010, 12:24 PM
  4. thin wall pvc for intake
    By wade722 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-24-2010, 06:30 PM
  5. Replies: 15
    Last Post: 03-17-2010, 05:06 PM
