Thread: Getting new tranny from TEP, a couple of questions
Results 1 to 3 of 3
  1. #1 Getting new tranny from TEP, a couple of questions
    Denver
    1) How long should I leave the ATF in the tranny after rebuild? Is it like an engine where you use break-in oil for 200 miles and dump it? Basically, I don't want to put $130 of new ATF in there just to replace it in a week (I will use the cheap stuff if that's the case)
    2) Synthetic or conventional?
    3) Is it worth replacing my PS rack now that I have the cradle off? It doesn't leak and works fine - so that might seem like a dumb question. But, I don't know how long they usually last.
    Ohio
    1.) no you'll leave the same fluid in there. Just be gentle on it for the first 500 miles.
  3. #3 Re: Getting new tranny from TEP, a couple of questions
    if you have super high miles, then changing the rack may be a good idea, it will never be this easy to change it again.
    you'll likely need and alignment after you put the sub frame back up anyway.
  1. Couple of questions....
    By Koniig in forum 5.3L V8 (LS4)
    Last Post: 05-23-2011, 02:45 PM
  2. new here and got a couple questions
    By jayn in forum General Tech Discussion
    Last Post: 10-27-2010, 01:06 PM
  3. couple of questions, couple of issues
    By zero in forum General Tech Discussion
    Last Post: 12-30-2009, 04:48 PM
  4. A couple of questions.
    By Enjoijoe in forum General Tech Discussion
    Last Post: 04-12-2009, 07:56 PM
  5. I have a couple of questions.
    Last Post: 03-12-2009, 07:07 PM
