BabyGrandPrix
i reset the computer and going to wait till i put about another 50 miles or so then gonna run the computer again to make sure. but 3 codes came up po336 the crank position sensor. po716 the transmission speed sensor which i put new transmission fluid it cause it was a little low and that might of been the problem and the other code was po742 the torgue converter clutch. but again i reset the compouter and will check again after a little more miles to make sure its the problems i think it is so i dont go through to much trouble on trying to fix something hard that could possibly be a easy fix. ill keep updates on how the cars running. yesterday it didnt tick at all and today on my way home from work it ticked a little bit but for about 5 minutes. ill find out tomorrow if there are any more noises i should worry about.
