Thread: trans ticking noise? Shifts fine...
Results 1 to 4 of 4
  1. #1 trans ticking noise? Shifts fine...
    GT Level Member m17davis's Avatar
    Orland Park, IL
    Alright guys. So this strange noise started a couple days ago. Its a 2000 gtp with 146*** miles. At cold start up it doesnt make the noise. But after a minute or two its starts ticking. It sounds like its coming from the passenger wheel well. It ticks in park neutral reverse drive 3 and 2. But when i puit it in drive 1 it stops. So thats why i think it has something to do with the trans..... i dont know. please help. thanks
    Ported Gen III ~ 3.4 ~ HAI ~ 180stat ~ 605's ~ Speed Daddy's ~ SLP Catback ~ A/C delete ~ Aluminum Sub-frame ~ AGX Coilovers ~ Vinnie Spacers ~ Fusebox & PCM Relocation ~ Wire Tuck
  2. #2 Re: trans ticking noise? Shifts fine...
    Apr 2009
    Fort Worth TX
    Does it do this noise only when moving?
    If so, it could be a lot of things:
    CV
    Yoke
    Wheel bearing
    Strut
    brakes
    It may not be the transmission.
  3. #3 Re: trans ticking noise? Shifts fine...
    Orland Park, IL
    it does it while in idle and a little throttle. it does not happen when i am giving it normal throttle.
  4. #4 Re: trans ticking noise? Shifts fine...
    Apr 2009
    Fort Worth TX
    Probably just the valve train. Open the hood and see if the noise is coming from the top of the engine and if it changes with engine RPM.
  1. ticking noise
    By Toms04compg in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-26-2012, 02:04 AM
  2. what is this ticking noise?!?!?
    By 2000gpgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-07-2011, 07:36 AM
  3. Ticking noise
    By ajoliver2010 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-04-2011, 10:22 PM
  4. l26 ticking noise...
    By Couch in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-02-2011, 12:05 PM
  5. ticking noise
    By SCbuick010 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-07-2011, 10:52 PM
