Thread: Weird Shifting Problem
Results 1 to 8 of 8
  1. #1 Weird Shifting Problem
    May 2012
    Burlington, Wisconsin
    Today I went to drive my GTP and realized it was shifting weird out of 2nd gear. Instead of shifting like, normal, it stayed around 3000-4000 rpms and didn't shift until i completely let off the gas. I decided to go faster and see if it would shift at a higher speed. As soon as I hit around 90 in second instead of shifting at redline it just kept revving and didn't shift. Is this a common issue with the GTP? Does anybody have any type of idea what it could be?
  2. #2 Re: Weird Shifting Problem
    May 2012
    Help me out guys :/.
  3. #3 Re: Weird Shifting Problem
    GT Level Member GMCustomerService's Avatar
    Michigan
    Btownmills,
    What year is the vehicle?
    Louis
    GM Customer Service
    Check out the NEW Owner Center at: My.GM.com
  4. #4 Re: Weird Shifting Problem
    May 2012
    It's a 98 with 128k on it.
  5. #5 Re: Weird Shifting Problem
    St. Louis
    When was the last time a pan drop/filter and fluid change was done? When was your last tune up? If you have any ignition related or sensor issues they can effect the way the trans shifts. Simply cleaning the TB and MAF can sometimes fix it.
    Other than that you may need to have this scanned by a code reader that can read the trans codes. And no, they do not set a check engine light so you may have some and not know it. Could be a bad shift solenoid, sticky 2-3 accumulator, valve body issue, etc.. Fill in some details and we can go from there.
  6. #6 Re: Weird Shifting Problem
    May 2012
    Quote Originally Posted by FordMan77 View Post
    I'm honestly not sure. I bought the car about a month ago with very little maintenance records from a friend. I haven't noticed any issues. But I'll get a scan done and try to get a code. Thanks a lot for the help man.
  7. #7 Re: Weird Shifting Problem
    Oct 2011
    Southington, CT
    some thing happened to me man and it turned out that the 3rd gear clutch was just about completely GONE. pieces were every where inside the tranny
  8. #8 Re: Weird Shifting Problem
    Jun 2012
    Washington State
    oops
  1. 95 GP Shifting problem
    By DaveB in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 10-22-2011, 03:53 PM
  2. First Run on the track, and weird shifting issue
    By speedy2 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-12-2010, 03:41 PM
  3. Shifting Problem
    By taximech in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-30-2010, 07:06 AM
  4. Shifting problem, pls help
    By mtrmes02 in forum General Tech Discussion
    Last Post: 01-23-2010, 09:07 PM
  5. Weird shifting problems
    By Sick03L in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-09-2008, 07:48 PM
