Thread: 01 to 97 swap
Results 1 to 6 of 6
  1. #1 01 to 97 swap
    SE Level Member chrisLB's Avatar
    Nov 2009
    canada
    I am swapping my trans in my 97 gtp with a trans from a 2001 is there going to be any problems? Or anything I will need to do to get it to work? Thanks
  2. #2 Re: 01 to 97 swap
    Jan 2012
    Philadelphia
    im not sure but why were on this topic i just was curious to someone who might know, if you have performance shift in your car and you get a trans from a car without it would the performance shift still work? is the performance shift just computer and electronic?
  3. #3 Re: 01 to 97 swap
    Nov 2009
    canada
    From what I've read the lines to the cooler are different on 97 HD trans and 00+ so if I use my aftermarket cooler and bypass the factory cooler that should work and be less of a headache right? Lol
  4. #4 Re: 01 to 97 swap
    GrandPrix Junkie
    St. Louis
    The fittings that go onto the trans at the other end of the line is what are different. Have to use the lines for the 01 then you can plumb your aftermarket cooler on the other end.
  5. #5 Re: 01 to 97 swap
    Nov 2009
    canada
    Well Im just going to cut the line and use a barb to use my 97 lines... Less headaches lol
  6. #6 Re: 01 to 97 swap
    Chris..you got it.
    Eddie.. all the performance shift stuff relates to programming. Has nothing to do with trans. So yes..it works either way.
  1. Replies: 1
    Last Post: 12-31-2011, 04:55 PM
  2. Fuel gauge dosnt work after wireing harness swap and motor swap
    By guimond47 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-02-2011, 06:01 PM
  3. gen v swap
    By Biggie1720 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-01-2010, 04:09 PM
  4. What wil i need to do a top swap
    By gp3800t in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-21-2009, 08:34 PM
