So, As some have seen. My old transmission bit the dust. I put another one in, It was a freebie we that we had at the shop out of a 98 Buick Park avenue. Car was flood damage.
Engine was used in another car with no problems. So I used the transmission with a new torque converter, Filter and fluids. It had a little water in the transmission which worried me but it was worth a shot. Transmission had been sitting out for a year.
There was no issues at first, Scanned it and i get a handful of codes, I cleared them earlier and they have yet to come back on but I do not know if they will or not, Or if it was just some fluke codes from it sitting with a little water in it.
P0140 (Existing)O2 Sensor Circuit Malfunction Bank 1 Sensor 2
P0443 (Existing Never could figure out the issue) Evaporative Emission (EVAP) Purge Solenoid Control Circuit
New codes
P0716 input turbine speed sensor.
P0717 Turbine Speed Sensor Circuit No Signal
P0730 Incorrect Gear Ratio
P1810 automatic transmission fluid pressure Valve Position Switch
