Thread: Cooler Lines
Results 1 to 5 of 5
  1. #1 Cooler Lines
    Kansas City, MO
    I just bought a new radiator for my 02 GT because the old one was cracked and leaking. the cooler lines do not match up on the new radiator. I have the threaded kind and it does also but the threads are smaller. Does anyone know if any adapters or if I should just return the radiator for another?
  2. #2 Re: Cooler Lines
    St. Louis
    Can you remove the fittings from your old cracked radiator and put them in the new one? I think I had to do this when I swapped my rad.
  3. #3 Re: Cooler Lines
    Kansas City, MO
    FordMan77, I tried this but the fittings are actually built into the radiator. any other ideas?
  4. #4 Re: Cooler Lines
    Usually new rads come with adapters, double check that box.
  5. #5 Re: Cooler Lines
    Kansas City, MO
    I will check when I get home. Do you know anything about a checkball and if my year has it? Because if it did I lost it and probably need to get another
  1. Replacing transmission cooler lines
    By Gnat in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-18-2011, 07:00 PM
  2. Transmission cooler lines
    By jakeb157 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-01-2011, 12:09 PM
  3. Transmission Cooler Lines
    By tdm571 in forum The Rant Forum
    Last Post: 02-27-2011, 07:17 PM
  4. Transmission Cooler Lines
    By topswap in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-01-2010, 08:53 AM
  5. Trans cooler lines, which is IN and which is OUT?
    By VinnieGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-30-2008, 11:45 AM
