Thread: 4T65E I think its done. No pull now.
Results 1 to 17 of 17
  1. #1 4T65E I think its done. No pull now.
    GT Level Member Brian99SE's Avatar
    Dec 2011
    Cadiz, Ky
    I figure its done now. My 99 Se has 253,000 miles on it. Yesterday i was on my way home. Just about a mile from home and I stopped to talk to a friend. Went to take off and nothing, Wouldnt move.
    I just sat there and raced it a few times in drive and it hooked in and took off. So i made it home where it sits now.
    Time to just drop another tranny? Or what happened? It clicks into reverse/drive like it normally would.
    99 Grand Prix SE-Blue CAI, 3.03 GR Transmission, U Bend Delete.
    time to call the exterminator
  2. #2 Re: 4T65E I think its done. No pull now.
    sounds low on fluid
  3. #3 Re: 4T65E I think its done. No pull now.
    Dec 2011
    Cadiz, Ky
    Checked when i got back to the house. Looked good.
  4. #4 Re: 4T65E I think its done. No pull now.
    Dec 2011
    Cadiz, Ky
    It definitive clicks and jumps when put in drive or reverse. Seems like the clutches arent releasing.
  5. #5 Re: 4T65E I think its done. No pull now.
    St. Louis
    When was the last time the fluid was changed? Is it making any whining sounds? Sounds like either fluid starvation (clogged filter) or something internal is shot. You could try dropping the pan, change the filter and refill w/ Dex VI and a quart of Lucas stop slip and see what that gets you. Cheaper than a trans replacement.
  6. #6 Re: 4T65E I think its done. No pull now.
    Dec 2011
    Cadiz, Ky
    yeah. I hear the pump whining. Last changed the fluid 20K ago.
  7. #7 Re: 4T65E I think its done. No pull now.
    Dec 2011
    Cadiz, Ky
    So I have a question, Will the transmission out of an 03 Buick Park avenue work in my 99 Grand prix SE? Both 3.8 powered cars.
  8. #8 Re: 4T65E I think its done. No pull now.
    03 can be made to work, look it up..there's a few things on it and rewiring a few pins.
    Try putting the trans into 2 or 1 and see if it's slippy. If so..the forward band broke.
  9. #9 Re: 4T65E I think its done. No pull now.
    Dec 2011
    Cadiz, Ky
    Theres nothing Bill. No forward or reverse. just Clicks/Clunks when moved from drive to reverse. I can un plug the main harness from the top of the tranny and get it to limp.
  10. #10 Re: 4T65E I think its done. No pull now.
    That's very odd.
    If it were diff, unplugging wouldn't help.
    If it were fwd band, 2-1 should help
    If it were serious metal soup, I wouldn't expect unplugging to help.
    Sounds like it's swap time. If you are up to it, there's a write up for swapping a trans. Overall not difficult, only time consuming.
  11. #11 Re: 4T65E I think its done. No pull now.
    Dec 2011
    Cadiz, Ky
    Bill, I stand corrected, The tranny is out of a late 97 early 98 Buick Park avenue Will it direct-swap?
  12. #12 Re: 4T65E I think its done. No pull now.
    In a pm to me you mentioned the connector looked to be the same. As long as the electrical connector is up on the side and not on the front next to a small coffee can with a vacuum port, you will be fine. That's the most obvious differences when looking at a 4T65E vs a $t60E.
  13. #13 Re: 4T65E I think its done. No pull now.
    Dec 2011
    Cadiz, Ky
    Soo Here goes nothing, Following Bills Tutorial on tranny drop, Its close to coming out, All I like is Power steering rack bolts, Flex plate bolts and drop the subframe, And out she comes. Great way to spend a friday night with my beautiful blue grand prix, Haha.
  14. #14 Re: 4T65E I think its done. No pull now.
    Dec 2011
    Cadiz, Ky
    I am going to tear the old tranny down once all is done and see what actually gave out. Im intrigued.
  15. #15 Re: 4T65E I think its done. No pull now.
    Dec 2011
    Cadiz, Ky
    Well, 9 Hours later and shes done. Back on the road. New Tq Converter and new alxes. Better than ever. Seems like it went in faster than it came out.
  16. #16 Re: 4T65E I think its done. No pull now.
    It does, because by then you've gotten acquainted with all the parts and have a better feel for which tools you need in which locations.
    One other thing that speeds it up tremendously for me that I intentionally left out of the write up is, I change the order of the procedure... I drain the trans, hang the motor and pull the subframe...then undo/remove the rest. The added clearance etc and no sub in the way makes it much easier. Being under and around a hanging drivetrain though is much more dangerous and not something I wanted a potential first timer to do.
  17. #17 Re: 4T65E I think its done. No pull now.
    Dec 2011
    Cadiz, Ky
    I understand that fully. I have NEVER dropped cradle, Done plenty of motor jobs but never had to mess with completely removing a cradle.
    Props on the write up, It helped tremendously.
  1. Tranny Swap 4T65E-HD to 4t65E
    By windowrattler in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-27-2012, 03:47 PM
  2. who knows sbc's? i think i have to pull the motor...
    By Poil336 in forum Off Topic Discussion
    Last Post: 03-03-2011, 10:43 PM
  3. 0-105 mph pull
    By gtpinsc in forum Off Topic Discussion
    Last Post: 05-02-2010, 09:32 AM
  4. 4t65E replacing 4t65e-hd question
    By guitarguyucf in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-29-2010, 10:33 PM
  5. got pull over today
    By nemesis in forum The Rant Forum
    Last Post: 06-25-2009, 02:59 PM
