Thread: Installing Cradle (cradle alignment pins)
Results 1 to 4 of 4
  1. #1 Installing Cradle (cradle alignment pins)
    GT Level Member JJ91284's Avatar
    Schaumburg, IL
    For those that installed there cradle, did you use those 19mm or .740 cradle alignment pins. I installed my cradle almost 2 months ago, and I noticed the cradle isn't matching up perfectly to the alignment pin holes.
    Where can you buy those pins?
    1997 Black GTP 72k (4dr), 3.5 Pulley, Wbody Downpipe, Wbody Shift kit (street), DHP 1.0, NGK TR55ix Spark Plugs, GMP Handling kit, KYB AGX Struts, AT Italia Inox 245x45x18 Goodyear Eagle F1, GMPP Springs, Corvette C5 Calipers, Blazertech 3200, DHP Powertuner (97-03), Built Trans, Torsen Diff
  2. #2 Re: Installing Cradle (cradle alignment pins)
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    I use a large center punch that is about a 3/4" diameter and has a long taper on the end. This works great and allows me to pry and move around the craddle so it lines up properly with the holes. I find often that most cars from the factory dont even have these holes lined up right and the car is aligned that way, so when you align the holes then the car has a pull to one side or the other because the alignment is off.
  3. #3 Re: Installing Cradle (cradle alignment pins)
    NE Ohio
    i didnt use anything when i installed my new cradle..just made sure everything linded up right.
  4. #4 Re: Installing Cradle (cradle alignment pins)
    SE Level Member alacran's Avatar
    Apr 2008
    Chicago, IL
    my question is how do you align the rear cradle?
  1. headlight patter alignment.
    By riceburner in forum Visual/Body Modifications
    Last Post: 09-04-2008, 11:16 AM
  2. Tightening cradle bolts
    By Sabrewings in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-26-2008, 11:06 PM
  3. Trouble with Alignment after new supsension.
    By John_Shughart in forum Brakes/Suspension/Chassis
    Last Post: 04-08-2008, 06:36 AM
  4. wiring connector pins
    By Toasty in forum General Tech Discussion
    Last Post: 01-20-2008, 01:12 AM
