Thread: torque converter clutch (tcc) help.
Results 1 to 8 of 8
  1. #1 torque converter clutch (tcc) help.
    Mar 2012
    Michigan
    Ok, so I have a 98 gp gtp and my tcc selenoid is stuck on and i do not have the money to fix it right now. I was told to go from reverse to ddrive until it comes unstuck. Then they told me to unplug the fuse for the tcc so it won't engage. All they said the worst thong could happen is worse millage on the expressway. I have tried this for a little while and I didnt work. Is there anything else I can do to help it get unstuck without taking the transmission pan off. Please and thank you!
  2. #2 Re: torque converter clutch (tcc) help.
    Saratoga NY
    The pan wouldnt come off the side cover would.
    You can use a scanner to clear the code, it will likely come on soon after though.
    A bottle of trans juice might help, lubegard is good, maybe a generic stop slip or treatment additive might help.
    98-XP e85 SSAC HPT AGX Bullets Every BRM piece home built trans
    99-HPT ssic headers ported blower
    94z28 with a cam that chops so hard it hurts def peopels ears.
  3. #3 Re: torque converter clutch (tcc) help.
    Who is "they"
    One person here I think pulled the wire out of the connector to kill power to the TCC and that helped him for a while.
  4. #4 Re: torque converter clutch (tcc) help.
    SE Level Member harner's Avatar
    Apr 2012
    New Ringgold, PA
    I have the same issue going on. I heard many different "fixes" for this issue. Some people just assume their transmissions are shot and have them rebuilt. Others replace the sensors and they are good for awhile. Some people also get rid of them by running Seafoam or another additive. I'll probably try the Seafoam trick myself and see if it clears up the problem on my 180k trans.
    Code I have: P0742 Torque Converter Clutch Circuit Stuck On
    I also have no overdrive and what feels like a somewhat shakey shift between 2-3.
    1998 Grand Prix GT Sedan - SOLD
    10 Camaro 2SS/RS | 94 TA | 87 IROC | 06 Silverado 1500
  5. #5 Re: torque converter clutch (tcc) help.
    Your lack of 4th is the splines on the 4th clutch hub being stripped out. In your case, i'd go in swap that hub and soleniod and be a happy camper with a good trans.
  6. #6 Re: torque converter clutch (tcc) help.
    Dec 2011
    jackson tn
    does anyone have a diagram or know what color wire is to the TCC?
  7. #7 Re: torque converter clutch (tcc) help.
    Looks like U and yellow in this info. That was for a bonneville though, so color might be different.
    http://www.grandprixforums.net/how-a...ion-49297.html
  8. #8 Re: torque converter clutch (tcc) help.
    Dec 2011
    jackson tn
    ok thanks alot,
    Is there a way to disable it by using the brake switch for the pedal?
  1. Torque converter clutch
    By Teddyb in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-09-2012, 08:38 PM
  2. Torque Converter
    By justaV6 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-12-2012, 08:09 PM
  3. Torque Converter
    By fri3dchick3n in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-28-2012, 06:43 AM
  4. Torque converter clutch engages...boost climbs with throttle
    By xxmattfxx in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-21-2011, 08:51 AM
  5. Bad converter clutch??
    By skalor in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-08-2010, 10:29 AM
