Thread: Tap Shift???
Results 1 to 8 of 8
  1. #1 Tap Shift???
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    my GP didnt come standard with the tap shift, is there any kit you can buy to add this?
    2011 Honda Civic EX-L - Leather/Sunroof/LOADED!
    2009 Saturn Aura XE - I got shift paddles!!!
    '98 Olds Cutlass - Good, Dependable
    '06 GP GT S/C - Traded it in
  2. #2 Re: Tap Shift???
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    The Tapshift transmissions are specific for using this feature and have a different valve body and channel plate to accomodate this. The tapshift models have a valve to regulate pressure in manual 2 and 1 to its not so brutal. Non tapshift transmissions run near max line pressure in manual 2 and 1 ranges for extra holding power for engine braking where shifting isnt used regularly.
  3. #3 Re: Tap Shift???
    Aug 2008
    Fayetteville, NC
    can you do it? =P
  4. #4 Re: Tap Shift???
    GT Level Member BackInBlack's Avatar
    Vermont
    I temporarily made one for my 97 4T60e, but it was real violent, and I don't recommend repeating. Don't think anything I can build will work with the 4T65e, as there is a lot of feedback to the PCM from the transmission.
    The GPs are long gone...
  5. #5 Re: Tap Shift???
    Aug 2008
    Fayetteville, NC
    i really like the tap shift, i'd hate to have to trade for a comp G or something.
  6. #6 Re: Tap Shift???
    SE Level Member bentendo92's Avatar
    Aug 2008
    New Hampshire
    If you've already got a lot into your car, it might make more sense to get the appropriate tranny, along with all required components, and basically make it a comp G with tap-shift. That is one of the things I was thinking I might do if I ever get to a point where I can make my GP a pure project car, and not just my daily driver.
    04 GTP.
  7. #7 Re: Tap Shift???
    Moore, Oklahoma
    Not worth it IMO. Sure you may play with it a few times, but then you'll never use it. Not worth the money to install it on your car or trade your car for a CompG. Besides, in the 1/4 a built/tuned tranny auto shifting will do better than you manually shifting the whole way, I can just about guarrantee it.
    Shawn W. Larsen
  8. #8 Re: Tap Shift???
    Aug 2008
    New Hampshire
    Quote Originally Posted by Iron Indian View Post
    That is most likely true... but God I just love the looks of those little paddles on the steering wheel...
    04 GTP.
  1. Shift Kit[*]
    By Trannyman95 in forum How To Write-Ups/Tech Tips
    Last Post: 06-03-2012, 01:40 PM
  2. No 2 to 3 shift until HOT
    By Brando in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-30-2008, 11:40 AM
  3. ZZP Shift Kit
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 03-29-2008, 08:19 PM
  4. Getting a shift kit
    By ryangtp89 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-19-2008, 10:20 PM
  5. shift kit
    By stlmo_gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-13-2008, 06:25 PM
