Thread: passenger side axle seal
Results 1 to 5 of 5
  1. #1 passenger side axle seal
    Sep 2011
    Mtl
    hi there,
    So the passenger side axle seal is leaking on our 2007 GP base. I did a search through this forum, found many ways to change it. But would lots of fluid leak out? cause in the diy, http://www.grandprixforums.net/how-r...xle-39805.html looks like lots of fluid comes out... but i've seen other posts, and videos
    GM 4T65E HD (2000 yr) Park Ave 3rd GEN (How to Replace Transmision Output/axle shaft seal) - YouTube
    drivers side
    thank you for any help.
  2. #2 Re: passenger side axle seal
    Portland Oregon
    You're probably going to lose a quart. However, you can minimize your loss if you hack the passenger side up as far as you can first.
  3. #3 Re: passenger side axle seal
    Jack up just th passenger side as mentioned. it's less fluid that way.
  4. #4 Re: passenger side axle seal
    Denver
    If you jack the car up (as you need to in order to remove the wheel and axle) then NO fluid will leak out.
    I've changed both axles and seals on my 98 about 4 times each and never used a pan.
  5. #5 Re: passenger side axle seal
    Sep 2011
    Mtl
    Thank you fellow gp'ers.... good to know!
  1. passenbger side axle seal STILL LEAKING FFS!
    By SJAndrew in forum General Tech Discussion
    Last Post: 08-18-2016, 10:41 PM
  2. Axle seal - AGAIN (driver side this time)
    By SJAndrew in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-20-2012, 01:23 PM
  3. Passenger side (right) axle seal
    Last Post: 07-05-2012, 01:53 PM
  4. Axle passenger side.
    By VGPGT in forum General Tech Discussion
    Last Post: 01-31-2012, 09:44 AM
  5. Passenger Side Axle Seal Replacement
    By Rob3800 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-30-2008, 04:35 PM
