Thread: How much HP can a 4T65E-HD 2.93 trans handle
Results 1 to 20 of 35
  1. #1 How much HP can a 4T65E-HD 2.93 trans handle
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    i just had my trans rebuilt in my 99 GTP they did all the basic upgrades there not a performance shop but its not an original trans if you know what im saying. what im wondering is what kind of crank horse power can this trans handle? stock is 240hp and 280torque. i was considering modding it to reach 300hp and 350torque at the crank
  2. #2 Re: How much HP can a 4T65E-HD 2.93 trans handle
    you'll be fine.
    Just slap a transgo shift kit in there as well.
    FWIW, it holds the same as a non HD: Not much when abused.
  3. #3 Re: How much HP can a 4T65E-HD 2.93 trans handle
    Oct 2011
    Michigan
    i was going to do Headers, cat-back, intake, overkill PCM, 3.4'' pulley, and all little supporting mods which i figure is about 300hp at the crank at least. you think my rebuilt trans can handle that? i wont abuse it but i wont baby it all the time
  4. #4 Re: How much HP can a 4T65E-HD 2.93 trans handle
    Pennsylvania
    Quote Originally Posted by asite57 View Post
    At least? Maybe 270.
  5. #5 Re: How much HP can a 4T65E-HD 2.93 trans handle
    Oct 2011
    Michigan
    Quote Originally Posted by SlowNA06 View Post
    270? are you kidding me im not only gonna get 30CHP from all those mods
  6. #6 Re: How much HP can a 4T65E-HD 2.93 trans handle
    Pennsylvania
    Prove me wrong.
  7. #7 Re: How much HP can a 4T65E-HD 2.93 trans handle
    Out West
    itd be fine at that power level.
    add a valvetrain mod or two for 300 at the crank though.
    Whine with your Cheese?
    Stock+Self Tuned. Going for low 14's everyday.
  8. #8 Re: How much HP can a 4T65E-HD 2.93 trans handle
    GTX Level Member f3racer's Avatar
    dongducheon, south korea
    4T65E-HD_Specs.doc
    if the gxp trans cant even handle the 303 flywheel stock then i doubt yours will handle it.
    SSG US Army Military Police
    2006 Grand Prix GXP
    http://gmls4.com
  9. #9 Re: How much HP can a 4T65E-HD 2.93 trans handle
    Oct 2011
    Michigan
    Quote Originally Posted by f3racer View Post
    4T65E-HD_Specs.doc
    are you being sarcastic?
  10. #10 Re: How much HP can a 4T65E-HD 2.93 trans handle
    Northeast Ohio
    4T65E-HD_Specs.doc
    you pulled up specs on a standard 4T65 not a 4T65e-HD
  11. #11 Re: How much HP can a 4T65E-HD 2.93 trans handle
    Quote Originally Posted by 06PONTGP View Post
    no, read it over again man. if you look it says engine ranges 2.5 to 5.3, and this spec sheet covers the mn7 which is the hd version of this trans. which is what is in my gxp.
    2006 Grand Prix GXP
    http://gmls4.com
  12. #12 Re: How much HP can a 4T65E-HD 2.93 trans handle
    Charles City, IA
    They will hold the same amount of power. and you might hit 280 with that setup.
    SMGPFC Two Nipple General
  13. #13 Re: How much HP can a 4T65E-HD 2.93 trans handle
    Oct 2011
    Michigan
    i get what hes saying though the GXP has the same trans and it puts out 303hp
  14. #14 Re: How much HP can a 4T65E-HD 2.93 trans handle
    Charles City, IA
    And they have a ton of transmission problems.
  15. #15 Re: How much HP can a 4T65E-HD 2.93 trans handle
    It runs way hotter than yours aswell, thus shorting its life.
  16. #16 Re: How much HP can a 4T65E-HD 2.93 trans handle
    My original trans is still kicking at 212K miles and I've had a 3.4 setup for about 8-9 months.
  17. #17 Re: How much HP can a 4T65E-HD 2.93 trans handle
    Oct 2011
    Michigan
    heres the set up i want to run
    Headers
    3 inch cat-back Exhaust
    3.6 inch pulley
    FWI
    Overkill PCM
    along with the appropriate tsat spark plugs and s/c belt
    will this set up break my brand new rebuilt trans?
  18. #18 Re: How much HP can a 4T65E-HD 2.93 trans handle
    throw a shift kit in there and you'll be fine.
  19. #19 Re: How much HP can a 4T65E-HD 2.93 trans handle
    Oct 2011
    Michigan
    i have a shift kit stock
  20. #20 Re: How much HP can a 4T65E-HD 2.93 trans handle
    No gp has a shift kit stock.
  1. 4t65e trans
    By bigtee in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-19-2010, 10:20 AM
