Thread: Jacking points during trans install?
Results 1 to 3 of 3
  1. #1 Jacking points during trans install?
    Aug 2008
    Hamilton, OH
    Don't know if this counts as a stupid question, but I'll post anyways. My wife's 99 with 216k miles blew a trans recently. The original lasted 171k, the rebuilt lasted 61k.
    I wasn't willing to spend another $2k on a car with this many miles, so I got the car back from the garage (w/transmission removed and in the trunk), and I plan to buy a junkyard tranny and see if I can't get another year from the car. I'm in OH, so maybe Cherry Auto?
    Anyways, I need to get the front of the car in the air, and I need to know the best places for jacking. I do have a jack with a long arm, so I can get the car in the air a good distance.
    So, best places for jacking, and any tips for getting the transmission in? I'm not going for hp or anything here; just putting a stock transmission in?
    thanks in advance for answers
  2. #2 Re: Jacking points during trans install?
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    Just jack up in the center of the craddle just behind the radiator, larger front frame section you cant miss it, and then put jack stands on the frame section of the floor just behind where the craddle bolts to the bottom of the car. If you look under the sides of the car just below the front edge of the doors you will see a pinch weld with some notches in it for using the vehicle supplied jack for changing tires. Look about 10" in past this area for the supports in the floor and put your jack stands here to let the car sit on. If you are looking for a used trans in Ohio then I would call Morad Parts Company in Cleveland as they are probably one of the largest suppliers for parts for these cars and I know they have plenty of transmissions. Their number is 216-671-3736
  3. #3 Re: Jacking points during trans install?
    Aug 2008
    Hamilton, OH
    Thanks! The x-member looked beefy enough, but it's always good to verify.
    Sean
  1. respect points etc.
    Last Post: 07-09-2008, 11:34 PM
  2. Shift points
    By TDCRacing in forum General Tech Discussion
    Last Post: 05-28-2008, 02:26 PM
  3. Reputation points?
    By GreenNirvana101 in forum Off Topic Discussion
    Last Post: 04-15-2008, 05:29 PM
  4. Iron Indian Trans Install (Pictures)
    Last Post: 03-18-2008, 04:46 PM
  5. WOT Shift Points...RPM/MPH
    By japslpr in forum PCM Tuning
    Last Post: 02-04-2008, 07:12 PM
