Thread: 05 Grand Prix GT shift bang into gear
Results 1 to 10 of 10
  1. #1 05 Grand Prix GT shift bang into gear
    Moorhead, MN
    My 05 grand prix with 130k will bang into gear after stopping at a stop sign/light. It wont do it at every stop but when it happens, it is bad. The car will start to take off and then just bang into gear, and then will shift fine through all gears. I have noticed it usually happens after the car has been driven for a long period(45min or so). I have dropped the pan and changed the fluid (Dexron VI) and filter, and also installed the transgo shift kit(the springs in the accumulator). None of that really helped. The engien runs great, the tranny feels strong pulls hard no slipping. Was just wondering if it could be the EPC or TCC solenoid?
  2. #2 Re: 05 Grand Prix GT shift bang into gear
    GT Level Member torq455's Avatar
    Dec 2008
    Alabama
    Sounds like it's slipping during the 1-2 shift. Pretty much means it's time for a rebuild. Does it kinda feel like it's going into neutral during the shift too, at least a little?
    2002 GTP: K&N, 3.2 pulley, flipped mounts. ZZP SS headers, 180 stat, NGK TR6's, MSD wires, Reptile ported TB, ported S/C, ported LIM, Intense Stage II heads with larger Manley severe duty SS valves, Yella Terra 1.9 full roller rockers, LS6 springs, Racetronix fuel pump re-wire, Oil pressure "kit", JMB FWI. Mustang dynoed at 240 WHP, 272 WTQ.
  3. #3 Re: 05 Grand Prix GT shift bang into gear
    Moorhead, MN
    Doesnt really feel as if it slips at all. It takes off nice and strong but when it makes the shift into second it bangs hard, and happens really quick. Is there anything else i could try or should try before heading down the rebuild road? thanks
  4. #4 Re: 05 Grand Prix GT shift bang into gear
    Two things are the most common causes of this in our transmissions. First is a bad input piston seal/worn piston sealing area. The other is a leak in a channel plate gasket.
    What happens is fluid bleeds off, the pcm see's that the engagement hasn't happened and maxes out pressure which overcomes the bleed off. Bang, into gear you go.
  5. #5 Re: 05 Grand Prix GT shift bang into gear
    Dec 2008
    Alabama
    I was thinking a broken 1-2 accumulator spring.
  6. #6 Re: 05 Grand Prix GT shift bang into gear
    Moorhead, MN
    Thanks for the replys. just wondering now if there is anyway to check either of those problems? how far would you have to disassemble the tranny to check either of those parts? can a scan tool be used to look at any of the shift data for possible cause? i have access to the gm tech2.
  7. #7 Re: 05 Grand Prix GT shift bang into gear
    The accumulator spring is a pan drop and few screws, very easy. I've never come across that issue, therefore didn't mention it, but yeah..if that's a possibility, easy to check.
  8. #8 Re: 05 Grand Prix GT shift bang into gear
    Moorhead, MN
    thanks guys, ill do some checking and see if i find anything.
  9. #9 Re: 05 Grand Prix GT shift bang into gear
    Moorhead, MN
    Just a quick update on this issue. i relpaced the pressure control solenoid about a month ago, and the problem hasnt acted up since, i have my fingers crossed for now.
  10. #10 Re: 05 Grand Prix GT shift bang into gear
    Apr 2009
    Fort Worth TX
    That's strange. If the EPC solenoid was bad then it should have been banging into all gears. It should have set a code, P1860 I think. HMMMMM.
    You can tell I've had this problem before.
  1. 2004-2008 grand prix gear shifter
    By ham4864 in forum Visual/Body Modifications
    Last Post: 11-15-2011, 04:20 PM
  2. Grand prix issue w/gear i think
    By Vette Zr1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-01-2011, 07:08 PM
  3. 01 grand prix 3.8 gt not going into 4th gear at all
    By wiredup in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-18-2010, 01:23 PM
  4. 97 Grand Prix GTP Tranny shifts into 2nd gear late
    By Reeddawgy in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-28-2008, 08:32 PM
  5. 2000 GTP 1st gear slip/bang issue
    By Progas in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-21-2008, 11:12 PM
