Thread: zzperformance master overhaul kit questions
Results 1 to 14 of 14
  1. #1 zzperformance master overhaul kit questions
    SE Level Member 04GT's Avatar
    Sep 2011
    Brown City, MI
    i have a 2004 Grand Prix GT2
    first off,
    is my tranny the HD?
    how can you tell?
    annyways, will this kit from zz performance work??
    http://shop.zzperformance.com/store/...rhaul-Kit.aspx
    and if it will, how long would it take to put in? does the trans need to come out? or can i get it all from the pan?
    thanks for help!
    04 GP GT, dual borla exhaust, 24x4.5in tips, 18'' rims, audiobahn system, tinted 5%, windshield 35%, tinted tails, AVS HL covers
    MSD super conductor plug wires, autolite 606 plugs, shift kit,10k HID Low's, 8k HID High's, 8k HID Fog's
  2. #2 Re: zzperformance master overhaul kit questions
    1. No you dont have a HD trans, prolly more like 3.05's gears, maybe 3.29's. Those newer trannys got alot of different combo's.
    2. Why do you need that kits?? That looks like its just a complete seal kit with no internal parts.
    3. Yes the tranmission needs to come out of the car and would need to be taken all apart to redo every seal inside.
    4. I would not recommend you do this if you dont have any transmisson repair work experience.
    5. What makes you think you need to do this?
  3. #3 Re: zzperformance master overhaul kit questions
    Sep 2011
    Brown City, MI
    1-2 shudder, hard lag from P to D, just an overall loose feeling in my trans. 155k
  4. #4 Re: zzperformance master overhaul kit questions
    "loose" feeling?
    "lag"?
    Sounds like a stock PCM, a transmission that needs a pan drop and filter change with possibly the addition of a shift kit...and a line pressure adjustment in the file...and new motor/transmission mounts.
    There, I win.
    Probably need to clean the MAF sensor and your Throttle Body as well.
  5. #5 Re: zzperformance master overhaul kit questions
    Replacing seals wont help any of that.
  6. #6 Re: zzperformance master overhaul kit questions
    Sep 2011
    Brown City, MI
    great post! thanks, i was wondering about motor mounts ( how will i know if their bad?) shift kit has been ordered... and i didnt notice that kit only came with seals. how do i clean MAF sensor? and adjust line pressure? more or less? im an ase trainee.. so i know my fair share. buut no details. thanks!
  7. #7 Re: zzperformance master overhaul kit questions
    A worn input piston seal area is common to our transmissions and can contribute to what you are talking about. Worn valve body parts/bores etc also contribute, as do wearing clutches taking longer to engage than say fresh, properly clearanced clutches.
    Without some specific tools for the 4T65E and some experience, you don't want to rebuild a 4T65. It's not all that bad, it's very time consuming.
    Lapeer,MI
    Bill what tools will I need?? I'm in the process of a overhaul
    Sent from my DROIDX using Tapatalk
    Expect to spend north of a grand.
  10. #10 Re: zzperformance master overhaul kit questions
    Donating User Odi's Avatar
    Chicago South Suburbs
    ride it till it blows, then get a used tranny. cheaper.
  11. #11 Re: zzperformance master overhaul kit questions
    At the very least you want an input/3rd carrier ring resizer and a clutch compressing tool. The rest I was able to work through. Not easily in some areas. But you can get by with just those.
    Lapeer,MI
    Bill i got the one for the input shaft off ebay. Where did you get the one for the 3rd shaft rings?? Is that also called the turbine shaft??
    Thanks - as far as a spring compressor i made my own. When i get some time I'll take some pics of it. And sorry for the thread jack.
    Sent from my DROID RAZR using Tapatalk
    Lapeer,MI
    Forget mu question Bill, I found them all, cheap i might add ;-)
    Rich
  14. #14 Re: zzperformance master overhaul kit questions
    I paid $40 for the teflon ring resizer I think.
  1. ZZPerformance HV3 Upper Insert
    By aziff in forum General Tech Discussion
    Last Post: 05-07-2011, 06:48 PM
  2. Is the ZZPerformance package 2 worth it ?
    By AmericanRiceEater in forum General Tech Discussion
    Last Post: 05-02-2010, 10:26 AM
  3. ZZperformance Cat Back Resonator?
    By xringshooter7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-23-2009, 11:08 PM
  4. What's up with ZZPerformance?
    By customline56 in forum Off Topic Discussion
    Last Post: 03-17-2009, 02:23 PM
  5. zzperformance powerlog
    By luckyjack04GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-04-2009, 02:24 PM
