Thread: flex plate or engine issue
Results 1 to 5 of 5
  1. #1 flex plate or engine issue
    SE Level Member pontiacgtp98's Avatar
    Mar 2012
    United States
    i have no gears and and now my car makes this noise
    http://<br /> <br /> <a href="http:/...><br /> <br />
  2. #2 Re: flex plate or engine issue
    Mar 2012
    United States
  3. #3 Re: flex plate or engine issue
    HUDSON
    If you have mechanical oil pressure gauge that you can put on to look at the oil pressure, that will help
    you tell if it a connecting rod bearing. Also, if the bearing is worn enough you will see metal flake in the oil,
    give it a look.
  4. #4 Re: flex plate or engine issue
    Mar 2012
    United States
    Originally Posted by Nixon
    could be a bad balancer or flexplate.
    if its my flexplate does this sound accurate. in drive i rev some and at some point the car begins moving and then once it did that i died and wont start back up it dims all power as if just starter cant turn it over anymore.. flexplate crossing fingers
  5. #5 Re: flex plate or engine issue
    If it were your flex. I'd expect you might see some signs of that by pulling the inspection cover for the flex. Dimming and not wanting to start sounds more like a bearing though. A bad flex typically breaks and causes noise only. Does not effect the motor or the way it runs. I could see a piece breaking and wedging the converter etc..so I won't say it's impossible for it to bind the motor...unlikely though.
  1. flex plate problems
    By butch2000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-10-2011, 07:08 PM
  2. Flex plate upgrade
    By rodman in forum Turbo
    Last Post: 12-12-2009, 12:25 AM
  3. flex plate
    By tihosick in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-10-2009, 10:25 AM
