Thread: gxp trans
Results 1 to 11 of 11
  1. #1 gxp trans
    SE Level Member 06GPGXP33's Avatar
    Dec 2011
    Parma Ohio
    so the past day or two i have been talking to different transmission shops around my city. i found one that gave be a good price of 1500$ to take the trans out them self, put a shift kit in it, reprogram it and put high performance internals in it. then put it back in. all under warranty. i know alot of people say go for a TEP trans but for the price and the reviews of this company im thinking about going for it. i was wondering if this is a good idea? he had said he did 8-10 of the ls4 trans in the past and have not had any complaints.
    06 gxp, k&n intake, magnaflow exhaust, trans cooler 8k h.i.d.s
  2. #2 Re: gxp trans
    Wichita
    I say go for it. $1500 is less than what I paid for an tranny OH.
  3. #3 Re: gxp trans
    Dec 2011
    Parma Ohio
    im going to i will let you know how it is after the install thanks
  4. #4 Re: gxp trans
    GTP Level Member joshv's Avatar
    canada
    seems too cheap ?
    2005 GXP / Cartuning Turbo Kit / meth / Cutout / Ported LS4 intake Manifold / HP Tuned / Custom 3" Cat-Back / Highflow Cat / SSC Springs / Poly Dogbone Mount's / 2nd Tranny /
    ( p/o track time12.6@109mph 1.7 60ft )
    Dec 2010
    DMV
    It does BUT sometimes you find good deals. Mines is being rebuilt now for 1200. I'm still shocked at the price.
  6. #6 Re: gxp trans
    utah
    sometimes you do..but trans shops are the numberone rip offs in the country. cuz you cant tell if they did change any of the internals...or with what until you take it all apart again. just had a place build a trans for my buddies dodge..installed, 2 weeks later boom...then didnt put the shift get or hardned cluthces in it that he paid an extra 800 bucks for
    Dec 2010
    DMV
    Hopefully it's a warranty included
  8. #8 Re: gxp trans
    GTX Level Member f3racer's Avatar
    dongducheon, south korea
    why not buy the parts for 850 from tep and then have a local shop do the work. then you know what parts you have.
    SSG US Army Military Police
    2006 Grand Prix GXP
    http://gmls4.com
  9. #9 Re: gxp trans
    Dec 2011
    Parma Ohio
    Quote Originally Posted by f3racer View Post
    lol that is really a good idea. i will do that. thanks
  10. #10 Re: gxp trans
    Part of the reason some places will do it cheap are they want the business. Because even if you aren't charging top dollar...staying busy pays the bills. Other times it's because they check the valve body to be good where TEP automatically puts in all the VB upgrades. They listen to things like the stator bearing to see if it's bad, TEP automatically changes the stator bearing because it's known to cause whining. Many places put in the called for number of clutches which can leave a lot of space in the packs, TEP modifies the clutch packs to ensure they are clearanced for the application and best engagement. TEP modifies spacer places based on the application.
    Let's talk about high performance parts in our transmissions. There are a couple of clutch packs like a Zpak etc floating around, but most have been used up and aren't being produced anymore as our platform has aged. Being a GXP you'd already have a hardened 4th hub, you'd already have the beefier parts in the trans like the pinion gear. There isn't much that a standard trans shop has available to call a performance part to add to a GXP 4T65E trans.
    Likely what they are doing is pulling it out, checking things over, fixing the VB if it's an issue, relining the clutches and tossing it back in. I hope they are also doing the seals, but that is a large amount of time and effort that would usually drive the price up.
  11. #11 Re: gxp trans
    ask him for the stage 1 kit. here is the email he sent.
    "Hello,
    Thanks for your parts inquiry. For a full rebuild for your application I would suggest our Stage1 High Performance Complete Kit which is $824.95. Complete Kit details are on our website and the performance kit adds a few more items including a performance ratio boost valve and sleeve kit. We sell used sprocket sets for $49.95 and you would need the 35/35 set to achieve a 3.29 ratio. The TCM must be reprogrammed to work with a ratio other than stock.
    For shipping we would need a full address to get an exact shipping rate. These kits normaly cost about $20-$25 to ship FedEx Ground.
    Thanks again for your interest, if you have any other questions let us know
    David Norris
    Email: Dave@tripleedgeperformance.com
    Website: www.tripleedgeperformance.com"
    2006 Grand Prix GXP
    http://gmls4.com
  1. Trans
    By 443pearl in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-05-2012, 02:05 AM
  2. 96 gtp trans
    By cb43x in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 02-06-2011, 05:46 PM
  3. gtp vs 85 trans am
    By bballa0740 in forum Track Sessions and Kills
    Last Post: 07-15-2010, 12:50 AM
  4. cant get my trans out
    By gpgtman83 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-31-2010, 10:46 PM
  5. Trans only or Trans + Engine
    By 98GTKen in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-23-2008, 12:01 AM
