Soo for those of you not familiar, the trans will randomly bang into first gear from a stand still, almost like it fails to engage at first, when you lightly ease into the throttle. Well. I went to a reputable trans shop and they ran a diagnostics test on it and found code P1573-PCM/EBTCM Serial Data Problem. He mentioned the problem was with the line pressure.
According to google it means that connection was lost between PCM and EBTCM (electronic brake/traction control module).
Soo. Yay for not needing a rebuild!
But now what?? They suggested that I go to "Redwine Automotive" here in Memphis, says they are the best when it comes to electrical problems. He said there were no loose or frayed wires, which I am going to go back over anyway. Sooo I'm not sure what to do.
I tell you what. I'm sorta confused what the EBTCM (EBCM whatever) has to do with transmission line pressure.
If you guys recall, I DID have my EBCM rebuilt, and I DO NOT have any trouble lights on, no CELs, no ABS/TCS lights, nothing. So I'm just confused.
What should I do? Can't have it slamming in first no matter how few and far between it does it, surely it can't be good for it.
Thanks guys! As always any and all help is greatly appreciated! Cookies will be given![]()
