Thread: output shaft play?
Page 1 of 3 123 LastLast
Results 1 to 20 of 44
  1. #1 output shaft play?
    SE Level Member chuckd98gtp's Avatar
    Apr 2009
    Long Beach
    Hey guys, I've been chasing a vibration for some time here now, had the cv axels replaced a few months ago. was changing my brakes today and looking around for anything obviously wrong and I noticed that the output shaft of the passenger side has about a half inch of play when moving it by hand. anybody tell me if thats normal?
  2. #2 Re: output shaft play?
    Moving it front to back or left to right?
  3. #3 Re: output shaft play?
    When you say output shaft of passengerside. You'd be talking about the axle. do you mean the outer most section that should be locked down to the wheel bearing with an axle nut is moving?
  4. #4 Re: output shaft play?
    Apr 2009
    Long Beach
    no, it would be the part coming out of the differential, and it moves left right up and down as well as in and out slightly
  5. #5 Re: output shaft play?
    That is part of the CV shaft.
  6. #6 Re: output shaft play?
    Apr 2009
    Long Beach
    ok, so should it have play?
  7. #7 Re: output shaft play?
    A little...
  8. #8 Re: output shaft play?
    Apr 2009
    Long Beach
    thanks
  9. #9 Re: output shaft play?
    Sorry I'm not more descriptive..
    Putting a trans together is a sloppy wobbly mess overall as you load the leg up. Then there's one or two pieces that hold most of it in place.. There needs to be some play.. question is..how much, right?
  10. #10 Re: output shaft play?
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    I also have been chasing a vibration in my 01 GP GT and have noticed this "play" (it feels like something in the trans must be loose like a bearing or something) the vibration i have occurs when im turning right and accelerating, accelerating over 70mph, or the cars suspension is compressed at high speed
  11. #11 Re: output shaft play?
    There is really nothing in the trans that can cause this.. especially on a turn. It can be an axle, wheel bearing etc. Those items are common to wobbles that come or go when the wheels change orientation.
  12. #12 Re: output shaft play?
    Donating Users moddman's Avatar
    Midwest
    Thats my question of the month......How much play should the differential stub coming out from the driver side trans have? 2001 GTP
    Put the car up on a lift thinking its cv shaft problem and took left cv shaft out and differential stub shaft have excessive play up & down side to side bearing noise.The reason for putting on the lift is the car doesnt move at first and then it moves forward and you hear a clunk come from the left side of the trans.
    3.4" ZZP MPS Pull
    ey,ZZP Coupler,NGK PLUGS,L67 Coils,INTENSE 1.8 RR, Custom PCM Tune, ZZP Stage 2 IC, 180* T-Stat, 42LB RE-FLWD Inj.
  13. #13 Re: output shaft play?
    Midwest
    A humming or growling noise, sometimes due to inadequate lubrication in either the inner or outer CV joint, is more often due to worn or damaged wheel bearings, a bad intermediate shaft bearing on equal length halfshaft transaxles, or worn shaft bearings within the transmission. Think I found my answer
    3.4" ZZP MPS Pull
  14. #14 Re: output shaft play?
    Apr 2009
    Long Beach
    Quote Originally Posted by moddman View Post
    we'll let me know ive just been letting it go, hasnt gotten any worse deff have a noise that sounds almost like ive got mud tires
  15. #15 Re: output shaft play?
    Midwest
    Quote Originally Posted by chuckd98gtp View Post
    Im sure Trannyman can chime in to help enlighten us about why the driver side stub shaft of the 4T65E-HD get loose to the point of not engaging intermittently causing noise in our 98+GTP cars.
    3.4" ZZP MPS Pull
  16. #16 Re: output shaft play?
    I don't believe that is what that info means. I've talked to Dave when rebuilding a couple of transmissions and he mentioned a large amount of a whining/growling being from the stator bearing. This particular bearing is where the input shaft comes through the casing from the torque converter to drive the chains. It shouldn't cause your clunk. I'd think that is either a bad CV shaft or a strut mount.
  17. #17 Re: output shaft play?
    Midwest
    Second set of CV shafts......so def ruled out.....and I saw my self how much play the stub shaft had. Plus the car moves and doesnt move until the shaft engages and moves the car.
    3.4" ZZP MPS Pull
  18. #18 Re: output shaft play?
    Midwest
    Guy this is what I need to be replaced. Anybody know of a good source for these? Thinking of just buying OEM.
    output shaft play? Attached Images
    3.4" ZZP MPS Pull
  19. #19 Re: output shaft play?
    That's some planetary stuff from down in. That plastic piece is the lube dam and the splined shaft you have goes into the 3rd gear sprag.
    I have 2-3 transmissions laying around and those parts should be good, or ebay, maybe a trans shop. Likely though, most shops won't stock them because they are standard hard parts that typically don't go bad.
    What when wrong with them?
  20. #20 Re: output shaft play?
    Midwest
    Those parts were not from my trans. they were just based on info from my research of symptoms the car has. I just authorized a full rebuild happening in a couple of days. Let the fun begin.......
    3.4" ZZP MPS Pull
  1. 4t65 Output Shaft Stuck
    By Admiral Jedi in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-02-2012, 08:22 AM
  2. Gun Drilled Output shaft
    By MidnightBlue in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-19-2011, 05:48 PM
  3. Output shaft questions?
    By johnsmith in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-10-2010, 07:58 PM
  4. Loose Trans axle output shaft (wobble)
    By PCweber in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-21-2009, 10:22 PM
  5. Q? Output Shaft removal
    By JoeMama in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-22-2008, 09:07 AM
