Thread: built Trans
Results 1 to 14 of 14
  1. #1 built Trans
    Dec 2011
    baltimore
    I know its a newb question but wat does a built Trans actually consist of?
  2. #2 Re: built Trans
    Ohio
    stronger input shaft, 4th hub shaft, larger chain, new clutch packs, shift kit
  3. #3 Re: built Trans
    upgraded hard parts, better clutches, updated valve body, tighter clutch packing etc.
    hard parts being a chain, input shaft for most. Gets more involved the further you go.
  4. #4 Re: built Trans
    Dec 2011
    baltimore
    Thanks guys im almost finished getting the parts I need for my top swap any website that actually sell built Trans? I was on zzp but they only have stock Transmissions would it be better 2 buy one built already or build myself?
    Ohio
    Have you ever tore into an automatic transmission?
  6. #6 Re: built Trans
    zzp will sell a built transmission.
    triple edge performance is our local supporting trans guy.
    Tim king will also build a trans for you.
  7. #7 Re: built Trans
    These transmissions aren't tough once you know what you want. Here's the way my list would go.
    TEP valve body/channel plate/spacer plate. They go through and do all the Sonnax/Transgo/etc upgrades along with new soleniods and tested pressure switches.
    Better stack of clutches, most places do this.... TEP says so and it's a good stack.
    Hardened 4th clutch hub: All do it
    New seals: Should be all do it
    Better input shaft: Something that is a "do you need it" item. There are a lot of guys putting down decent power on stock input shafts...the risk though is typically not worth it. I would recommend the Intense turbine shaft or the ZZP 300M.
    Chains: the V8 chains are good, definately better than the stock v6 chains. A 15/16 is brittle and they tend to break which is bad. 7/8 stretch with lots of power, but they don't snap typically. 1".. the end all be all.
  8. #8 Re: built Trans
    Dec 2011
    baltimore
    Im n automotive school now n they let us work on our cars there with help but no I have neva actually done a Trans before
    what states are the Trans builders n im in Maryland n im pretty sure the dnt ship transmission except locally???
  9. #9 Re: built Trans
    They'll ship anywhere
    Tim is in Ohio or Indy
    TEP is Indy
    ZZP is Michy
    Ohio
    Tims in Ohio
  11. #11 Re: built Trans
    Dec 2011
    baltimore
    How do I get incontact with those guy not zzp
  12. #12 Re: built Trans
    SE Level Member Mater's Avatar
    Feb 2010
    my house
    TEP has a web site
    Triple Edge Performance - Home Page
    not sure on Tim
    But why make it an SE?
    99 Grand Prix SE coupe:
    junk yard trans junk yard engine and junk yard turbo
    03 Silverado 2500HD ECSB: 6.0 4x4 01 Aurora:​ 4.0L vin number 2
  13. #13 Re: built Trans
    Isn't Tim registered here? Look for member Tim King on the forums. Soon you'll find him.
  14. #14 Re: built Trans
    Texas
    To get in contact with Tim King email him:
    Bad3800@aol.com
    it will cost you a little over 2K
    85 Corvette
    01 TA
    03 Z06
  1. p1629 with newly installed built trans
    By 01 GT in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-11-2010, 07:17 PM
