Thread: shift solenoid A
Results 1 to 11 of 11
  1. #1 shift solenoid A
    SE Level Member Thuglife2334's Avatar
    Apr 2011
    CT
    so my 2004 GTP comp G just hit 150,000 yesterday and today the shift solenoid A **** the bed code P0753.. anybody got any info this ... and or how to fix it or how much.. is my tranny all done .. or does it still have some life to ... any info will help??
  2. #2 Re: shift solenoid A
    Omaha, NE
    This codes refers to the 1-2 shift solenoid. Be sure to check all fuses first. Specifically the
    "TCC" fuse in the underhood fuse block.
    If that is ok, 2 things possible. Either you have a connector problem at the 20-way
    transmission case connector causing this code, or the solenoid. The solenoid is on the
    valve body in the side case of the trans.
    Suggest disconnecting trans. connector with key off, look at all terminal, pull the harness
    a little so as to change its position, then plug it back in. Clear the codes and drive it.
  3. #3 Re: shift solenoid A
    Apr 2011
    CT
    nice thanks man iam try that 2morrow at work .. thanks for the info
  4. #4 Re: shift solenoid A
    Al.. I have a test box that I make to command the soleniods directly w/o the pcm or any other nonsense. That would give you ability to test it out. Also..it's only a few hours to swap that out. Lower that side of the sub/drivetrain and sneak the cover out, flip in the new soleniod and presto.
    One of these links should tell you what ohm reading to get off teh soleniod. http://www.grandprixforums.net/trans...nks-42428.html Check to see if you are getting an open. Check that the pin at the 20 pin connector isn't pushed back etc.
  5. #5 Re: shift solenoid A
    Apr 2011
    CT
    yeah iam deff gotta take a look while the cars up!
  6. #6 Re: shift solenoid A
    Car doesn't have to go up for either of the suggestions I made. That connector is right up top of the trans.
  7. #7 Re: shift solenoid A
    Apr 2011
    CT
    oh ok good .. that makes it alot easier!..
  8. #8 Re: shift solenoid A
    You done testing yet? c'mon..in between ... have one of the guys do it.
  9. #9 Re: shift solenoid A
    Apr 2011
    CT
    yeah do it on my lunch break man! lol
  10. #10 Re: shift solenoid A
    It's already be diaged if it was Rich's car....poke poke
  11. #11 Re: shift solenoid A
    Apr 2011
    CT
    haha true hahah iam not that anal... if it blows up .. well ummm gotta start looking for a G8 GXP!!!
  1. shift solenoid (I'M ABOUT TO GET A BASEBALL BAT TO THE WHOLE CAR)
    By klynnh in forum General Tech Discussion
    Last Post: 10-19-2010, 01:13 PM
  2. Shift solenoid question
    By bretz in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-26-2010, 10:52 PM
  3. Shift lock solenoid
    By richard58 in forum General Tech Discussion
    Last Post: 11-17-2009, 04:45 AM
  4. Shift solenoid
    By Junixx in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-06-2009, 05:22 PM
  5. 1234 shift solenoid
    By ronaldgtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-12-2008, 06:11 PM
