Thread: Shift Kit or Not?
Results 1 to 2 of 2
  1. #1 Shift Kit or Not?
    Apr 2011
    Toledo, Ohio
    New to posting on the forum, have been a reader for a while.
    I have 2001 SE 3.1, so correct me if I am wrong but I have a 4T65E Trans.
    I have owned the car for a while with no serious modifications, I just enjoy the car as a daily driver and using it for autocross.
    I have seen a lot of disscussion on fluid flushes vs just pans drops, and shift kits to help with common trans problems. I am a little behind on changing the fluid in my trans (65k miles, 160k on car) and have had a few trans problems the entire time I have owned the vehical. I am planning on doing pan drop and was also considering a mild shift kit. My fluid looks good, no bad smell, but I do sometimes have bubbles on the dipstick. On WOT my transmission whines, and when it is hot I have hard shifts. I have read about the do's and dont's on transmission flushes as well as the arguments, so I want to stay away from a flush. I have also read that shift kits can help some transmission problems as well as a cooler. When I do this pan drop I was thinking on doing a zzp shift kit also. My question is can a mild shift kit be worse for my transmission, and if so are there any other options?
  2. #2 Re: Shift Kit or Not?
    i put a shift kit in my car and it helped out quite a bit then i got a tune that upped the line pressure and now it only slips if i'm out beating on it for a while and the fluid gets really hot. Also do a filter and fluid change it won't hurt anything.
  1. 1-2 Shift @ WOT
    By MstangsBware in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-15-2011, 03:17 PM
  2. which shift kit?
    By dmahlikGT in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-10-2011, 06:55 AM
  3. No 2 to 3 shift until HOT
    By Brando in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-30-2008, 11:40 AM
  4. Shift Kit[*]
    By Trannyman95 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-28-2007, 08:03 PM
