I have noticed that this grommet, fitting is leaking. I am thinking of doing my Transmission filter soon and figured it would be a good time to change this as well. Anyone know what part this is and if it is hard to change yourself?
Not really hard to fix, might just be an oring, mine is leaking from the other pipe going straight across lol
More than likely it is the fitting that threads into the case. The end of the cooler line is a quick connect style and there is an oring that seals that can leak with age but I have also seen the line be at fault as well. I would look at the rest of the cooler lines where the rubber section is crimped on and if either appear to be leaking I would replace the lines and fittings. These parts are dealer items, some places stock them and many dont but should have no problem ordering them in.
The rest of my car is spotless underneath. This is the only section if anything leaking.
Well, found a spot on the driveway this morning from this fitting. May be time to take it to the shop and have it looked at. Crap.
Do like Dave said...replace the o-ring?
It is going in tomorrow for a whole car inspection and estimate for getting fixed.
Those connections are bad and 2 new ones it is $10.... then new lines is about $45 for both lines. And they want to charge 2 hours of labor which would make my bill about $286.... umm, how hard are these to do myself?
