Thread: Transmission cooler lines
Results 1 to 8 of 8
  1. #1 Transmission cooler lines
    Hallstead PA
    Hey I have a 97 GTP and i cant remember which line from the trans goes to which line on the radiator. I disconnected them at the rubber hoes. i just dont want to mix them up and have problems.
  2. #2 Re: Transmission cooler lines
    Portland Oregon
    I know which one feeds on the trans. The feed is the one the has the u-bend dip in it and the strait one is the return.
  3. #3 Re: Transmission cooler lines
    Hallstead PA
    OKay so hook the feed on the tranny to the exit on the radiator
  4. #4 Re: Transmission cooler lines
    PA
    From this thread, which is stickied at the top of this section:
    http://www.grandprixforums.net/trann...ion-10095.html
    Heres the low-down on cooler line fitting thread sizes.....
    97-Most 99s:
    Cooler FEED fitting (points straigth down) 1/4-18 NPSF, NO CHECKBALL
    Cooler RETURN fitting ( Horizontal-points towards front of car) 1/4-18 NPSF
    Some 99s, all 00-early 04s:
    Cooler FEED fitting (points straigth down) 3/8-18 NPSF, HAS CHECKBALL
    Early 04 to current:
    Cooler FEED fitting (points straigth down) 9/16-18 UNF, NO CHECKBALL
    Cooler RETURN fitting (Horizontal-points towards front of car) 9/16-18 UNF
    2001 GSE
  5. #5 Re: Transmission cooler lines
    Hallstead PA
    thanks for your help guys
  6. #6 Re: Transmission cooler lines
    I think it feeds the top. that way if you are low on fluid..it falls to the bottom and you don't run dry
  7. #7 Re: Transmission cooler lines
    PA
    I always thought it was the other way around. I thought they fed the bottom of the radiator and return out the top?
    Can anyone confirm this? I'm not sitting at my car.
    Edit: I searched and found my answer:
    http://www.grandprixforums.net/trann...ler-32531.html
    The fitting on the transmission that points straight down towards the ground is the feed fitting that sends fluid to the radiator transmission cooler, which should be going to the bottom fitting on the radiator.
    The fitting on the transmission case that is parallel with the lower pan and points straight forward is the return fitting from the radiator and should be connected to the line going to the top fitting on the radiator.
    2001 GSE
  8. #8 Re: Transmission cooler lines
    Ya know..maybe it's like that to keep from having air issues because it's the highest point w/o a bleeder.
    Coolant you always see the feed going to top of the radiator and return coming out the bottom.
  1. Replacing transmission cooler lines
    By Gnat in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-18-2011, 07:00 PM
  2. Transmission Cooler Lines
    By tdm571 in forum The Rant Forum
    Last Post: 02-27-2011, 07:17 PM
  3. Tranny lines for trans cooler
    By monsterjam5000 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-12-2010, 04:09 PM
  4. Transmission Cooler Lines
    By topswap in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-01-2010, 08:53 AM
  5. Trans cooler lines, which is IN and which is OUT?
    By VinnieGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-30-2008, 11:45 AM
