Thread: whiney engine tranny
Results 1 to 4 of 4
  1. #1 whiney engine tranny
    Jul 2008
    dover
    i have an 01 gt 4dr 121,000 and when ever i go on the high way it makes a loud whiney sound from the engine when i hold the gas down in high gears and when i let off the whineing dies. plus my tranny will fade in and out. it will work emaculantely for a couple days then it will start to shift hard then go back to being good. never had it replaced and know its a lot of miles but. fluid is fine and everything. im selling it in a couple weeks just lookin for stuff to keep it working fine for a while
  2. #2 Re: whiney engine tranny
    TDCRacing
    Guest
    First off, Welcome to the forums. You may want to try posting this in the correct section wich would be the ''4 speed Automatic (4T60E)(4T60E-HD)'' transmission section of the forums. You will get a better response from there I promise. See you around and good luck.
  3. #3 Re: whiney engine tranny
    Oklahoma
    Welcome to the community.
    Moved this to the correct section. This way our resident transmission expert will see it and hopefully be able to offer some advice for ya.
  4. #4 Re: whiney engine tranny
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    Does the whining go away when it isnt shifting harsh? Does it make the noise sitting still and revving the engine? Not exactly sure what you mean by "trans will fade in and out", are you saying the tach will jump up and down a few hundred rpms going down the highway?
  1. Could it be an engine or tranny mount?
    By JCG's-GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2010, 11:12 PM
  2. Removing Engine and Tranny Together for Dummies Like Me (Write Up)
    By JoeMama in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-03-2009, 06:24 AM
  3. Help!! Tranny Swap Engine ''Refresh''
    By TDCRacing in forum General Tech Discussion
    Last Post: 06-10-2008, 12:04 PM
  4. Tranny???
    By Darkcelle in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-06-2008, 10:36 AM
