Thread: lube dam replacement in reaction carrier.....little platic yellow thingy
Results 1 to 3 of 3
  1. #1 lube dam replacement in reaction carrier.....little platic yellow thingy
    SE Level Member blown98gtp's Avatar
    Feb 2009
    iowa
    I'm having problems uploading a pic, but for those who have rebuilt their trans, I'm sure you will know which part I'm referring to. Mine is all chewed up. Is this part necessary, and if so, where do I find a replacement? thanks
    here's a link to a photo:
    Google Images
    98 gtp:L36/GenV/S1X/Pacesetters/FWI/Intense tune/timing commander/104s/P&P heads/DevilsOwn alky kit/ZEX dry shot/42.5#/shift kit/ScanGauge
  2. #2 Re: lube dam replacement in reaction carrier.....little platic yellow thingy
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    The lube dam helps to keep the geartrain lubed while everything is spinning and without it or if it is damaged/cracked it can cause lube problems and make shorter life of the gears in the front and rear planets. Often times this piece gets broken from removing an output shaft without removing the snap ring on either end of the shaft or if the fluid has been running too hot for an excessive time the plastic becomes brittle. We sell new lube dams if you dont have any luck finding one.
  3. #3 Re: lube dam replacement in reaction carrier.....little platic yellow thingy
    Feb 2009
    iowa
    pm sent
  1. ARP lube for rocker install. What for?
    By Rust in forum General Tech Discussion
    Last Post: 12-18-2011, 10:04 AM
  2. Silicon lube window rails?
    By tdm571 in forum General Tech Discussion
    Last Post: 06-01-2011, 08:42 PM
  3. Pontiac Seat belt strap thingy on eBay
    Last Post: 06-01-2010, 09:44 PM
  4. yellow fluid
    By backinblackgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-11-2010, 01:40 PM
  5. Caspers Electronic Timing thingy?
    By 2001GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-28-2010, 09:09 AM
