Thread: Transmission side cover help!
Results 1 to 9 of 9
  1. #1 Transmission side cover help!
    Jun 2010
    Illinois
    Gonna change the pressure solenoid for my 97 GP and have removed everything needed to get to the side cover of the transmission, but now i'm stuck! Does anyone know what size are the four lower Torx bolts and what is the best way to remove them? I hav'nt lowered the cradle yet, but want to find out if I need to lower the cradle first, then remove those bolts or is it best to remove the bolts first, then the cradle? ANY help would be appreciated! Thanks!!!
  2. #2 Re: Transmission side cover help!
    Waukesha, WI
    lower and support cradle first
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  3. #3 Re: Transmission side cover help!
    I forget if you can get a straight shot at them before you lower. I think you need to lower first. Then I am guessing because I know it's the 2nd or third in my set.
    check the bottom link (I can't view here) and see if it's in there.
    http://www.grandprixforums.net/trans...nks-42428.html
  4. #4 Re: Transmission side cover help!
    USA
    Quote Originally Posted by wrpfctr7 View Post
    The lower four torx bolts are T-40 and you want to make sure that the splines on the torx fitting are excellent. If they are twisted, don't use the torx fitting as it will probably strip the head of the bolt. I always used a new one when breaking these bolts or any torx bolt.
    Terry
  5. #5 Re: Transmission side cover help!
    There's Terry again.
    One trick I do use is to put the torx bit in them and give each of the four a good tap with a hammer to try and break the steel to aluminum bond.
  6. #6 Re: Transmission side cover help!
    USA
    Yes Bill, that's a good point. I also do the same thing, but forgot to mention it.
  7. #7 Re: Transmission side cover help!
    USA
    Oh, almost forgot. I believe the torx bolts are accessible before you drop the cradle, but you'll want to go ahead and lower the cradle and let the transmission and engine tilt to allow the cover to come off. I would take all the bolts out at that point.
    Terry
  8. #8 Re: Transmission side cover help!
    Jun 2010
    Illinois
    Thanks for the help! Gonna get the T-40 Torx, then lower the cradle first.
  9. #9 Re: Transmission side cover help!
    FWIW and I don't mean to be posting this a pieces. Get Craftsman torx bits. They'll always get rounded etc as you use them on this kind of thing. Then you simply zip over get your free replacement and it's all good.
  1. 4t65e side cover gasket $29.99 Advance auto
    By davevanoke in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-25-2013, 03:24 PM
  2. A/C cold on passenger side and luke warm on drivers side
    By IFrees in forum General Tech Discussion
    Last Post: 05-14-2011, 05:06 PM
