So I think the stumble in my RPM's is only happening when the car is in fourth gear.
The RPM's will fluctuate up and down a bit. But if I give it RPM and more gas it runs fine under boost.
From a dead stop it's fine also.
Driving in today I put it in 3rd gear for a bit on the highway where I notice it the most with little gas and rpm there was no fluctuating of the RPM's. Flip it back into forth and it starts again. It's not constant but happens every minute or less.
I replaced most all of my vacuum lines with silicone lines.
1999 GTP - running taylor wires, 605 plugs, short ram with open cone.
Any thoughts?
The codes I keep getting and haven't been able to figure out are
P0452
P0440
