Thread: 1-2 Shift @ WOT
Results 1 to 7 of 7
  1. #1 1-2 Shift @ WOT
    Aug 2011
    Tx
    Ran the car at the track the other night and found that at WOT the 1-2 shift will not happen unless I let of the gas. Once I barely let of the gas it shifts and off I go again with no issue. I thought I was hitting the REV limiter but the more I thought about it I had the same issue last time I was at the track(pretty sure was same issue). The trans shifts great other than that and still pulls hard with no odd noises.
    Since the last time I ran the car and now I have demodded and changed PCMs. I am pretty sure the issue I had the first time is the same as I had the other night but it has been over a year so not 100% sure.
    The trans is an 02 with 3.29 single gears and a 3K stall....
  2. #2 Re: 1-2 Shift @ WOT
    Charles City, IA
    sounds like you need a shift kit.
    SMGPFC Two Nipple General
  3. #3 Re: 1-2 Shift @ WOT
    Aug 2011
    Tx
    Quote Originally Posted by TheOtherNick View Post
    I have ran this trans for 60K or so and never had this issue before....I wish I knew forsure if the problem I just had was the same before I demodded the car. That would narrow it down to maybe something in the PCM....maybe line pressures.....
  4. #4 Re: 1-2 Shift @ WOT
    Did it bounce off the limiter? Did you have KR? Which maf/TPS are you running?
  5. #5 Re: 1-2 Shift @ WOT
    Aug 2011
    Tx
    I was not scanning so can not give any information on that....My thought was it was bouncing off the REV limiter as that is what is sounded like. Running a stock 98 TB........
    I wanna say this issue is the same one that came up last time I went to the track and the car was modded....But hard to be 100% sure being it was 1.5 years ago. Then I was running an LS1 TB with SLP MAF and a differant tune in the PCM....If I knew forsure then it would help out the troubleshooting....
  6. #6 Re: 1-2 Shift @ WOT
    Portland Oregon
    Do the trans tables in the PCM that you changed to have the same settings? Maybe it's tuned for a different final drive ratio
  7. #7 Re: 1-2 Shift @ WOT
    Aug 2011
    Tx
    Quote Originally Posted by OH4CompG View Post
    THis is what I am looking into now...Been talking with the guy that did my tune...
  1. Shift kit for 97 gt?
    By 97whitegt in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-07-2010, 11:15 PM
  2. Need help with a shift kit
    By MrClean in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-27-2010, 11:52 AM
  3. shift kit
    By CHAMPS97 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-19-2009, 09:27 PM
  4. No 2 to 3 shift until HOT
    By Brando in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-30-2008, 11:40 AM
