Thread: 06 Grand prix's tranny jerking
Results 1 to 6 of 6
  1. #1 06 Grand prix's tranny jerking
    Jul 2011
    Savannah,TN
    It all started this morning. Car has 115,000 miles on it. Started home from work and I noticed it jerked going from 1st to 2nd gear. Then it did it again! HELP!
  2. #2 Re: 06 Grand prix's tranny jerking
    MO
    check your fluid?
    <brandonl2000> LMAO D!!
  3. #3 Re: 06 Grand prix's tranny jerking
    Jul 2011
    Savannah,TN
    Quote Originally Posted by ZR1Vette09 View Post
    check your fluid?
    Yep,has plenty of fluid.
  4. #4 Re: 06 Grand prix's tranny jerking
    GTX Level Member tayl5645's Avatar
    Jul 2010
    Michigan
    your description is going to make it hard for people to diagnose what is going on. What do you mean by jerking? Is it shifting harder than normal or slipping. We need more details then "jerking". Any other symptoms associate with it?
    2005 GTP Grey
    Custom built Open cone intake, 15% tints all the way around, 7" touchscreen DVD player
  5. #5 Re: 06 Grand prix's tranny jerking
    Jul 2011
    Savannah,TN
    Quote Originally Posted by tayl5645 View Post
    Like it gets in a bind. Shifting hard. The dash shakes when it does it.
  6. #6 Re: 06 Grand prix's tranny jerking
    Pennsylvania
    Wow, thought this was a Drunkie thread.
    How many miles ago was your last transmission flush?
    Anyway, aside from making sure the fluid is full, it's also good to make sure it's a healthy pink color and not glittery.
    Also, make sure you scan for codes. Hard enough shifts will set off flags.
    Could always unplug the battery for an hour to reset the transmission stuff and have it relearn itself. Sounds to me like you've got a part clogged, worn or broken. Check here for some more good info.
  1. 01 Grand Prix GTP with tranny issues
    By Sweetser in forum Introductions/Noob Questions
    Last Post: 02-07-2011, 11:12 AM
  2. 2000 Grand prix Tranny problem
    By Slickgrandprix in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-04-2011, 04:45 PM
  3. 1988 Grand Prix Se -Need Help-AT Tranny
    By atomb in forum Pre-1988 3 speed Automatic TH-125C (3T40)
    Last Post: 08-02-2009, 10:24 PM
  4. 04 grand prix gtp needs tranny how much is it worth?
    By 98gtp1000 in forum 04+ Specifics
    Last Post: 06-10-2009, 04:43 PM
