Thread: 01 gt trans issue?
Results 1 to 4 of 4
  1. #1 01 gt trans issue?
    SE Level Member jpe's Avatar
    Jul 2011
    WI
    i have a 01 gt that im not sure if i have a possible trans issue or what it is? it will drive fine under light throttle and shift fine but if your going say 25 and floor it it will not shift but just go up to around 5k and stay there till you let off then it will shift. if your doing around 45-55 and floor it all it does is down shift and the rpm will go to about 4200 and stay there and wont really go faster than 60 mph unless you let off then it will shift and you can go faster? i just did plugs and wires but didnt really help. what could it possibly be? the car has 124k and just had the trans flushed and the new fluid still looks perfect. thanks
    08 gt mustang
    87 t top resto in progress
    01 gt grand prix (sold)
    01 se grand prix
  2. #2 Re: 01 gt trans issue?
    plugged cat maybe??
    pull the upstream o2 sensor and take it for a drive and see what happens, yes its gunna be very loud just so you know.
    or take the sensor out and stick a pressure gauge in the bung and see what it reads, if its over 1-2psi the cats clogged.
  3. #3 Re: 01 gt trans issue?
    Jul 2011
    WI
    where would i find a pressure gauge that will fit in the o2 hole?
    08 gt mustang
    01 se grand prix
  4. #4 Re: 01 gt trans issue?
    Jul 2011
    WI
    well chalk another one up to a plugged up converter. when i pulled it out it looked fine but emptied it anyway and reinstalled it and sure enough it runs way better and shifts fine. thanks guys
    08 gt mustang
    01 se grand prix
  1. trans issue.....no 1st or overdrive
    By glhtomni in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-28-2011, 08:48 PM
  2. Trans Issue
    By theone2043 in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 03-02-2010, 05:57 PM
  3. 2002 GP GT 3.8 N/A Trans Issue
    By GRANDPRIXBANDIT in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-14-2009, 09:03 AM
  4. Am I having a trans issue?
    By Brammer in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-02-2009, 01:56 PM
  5. trans. shuddering issue
    By monte0 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-23-2009, 08:21 PM
