Thread: One bad one good..
Results 1 to 20 of 25
  1. #1 One bad one good..
    GTX Level Member mofford12's Avatar
    Nov 2012
    Cincinnati
    Ok so I have a good working transmission out of a 97 gt.. 4t60e and I have a bad transmission, well at least I think it's bad.. It's in a 2001 impala.. I don't have any forward gears at all.. Only reverse.. Ok so my question is can I take some parts out of the 97 trans and put em into my 2001 trans to make it work again..
    I would like to trouble shoot the existing problem anyways so any tips or tricks let me know
  2. #2 Re: One bad one good..
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    No offense but if you dont know the answer to this question I highly doubt you have the special tools to remove the parts from the internals of your transmissions and swap them out. Again I don't mean to offend you.
    I went NA when a whore left -$300 in my bank account.
  3. #3 Re: One bad one good..
    Not sure there but I think some of the internals are the same. You'd be better off rebuilding what you have
  4. #4 Re: One bad one good..
    Nov 2012
    Cincinnati
    Quote Originally Posted by indygrandprix View Post
    Well lol I do have the tools.. I'm jus a noob on the trans.. I've never swapped or worked on one.. And no offense it's guys like you I don't understand people gather knowledge and the tools when they come to projects like these.. So what's a better time to learn..
  5. #5 Re: One bad one good..
    Nov 2012
    Cincinnati
    Have you ever redone a trans?
  6. #6 Re: One bad one good..
    Nov 2012
    Cincinnati
    And Indy I'm not bashing nor do I think you are.. We're jus sharing our opinions lol
  7. #7 Re: One bad one good..
    Ohio
    Don't lose a check ball...
  8. #8 Re: One bad one good..
    Nov 2012
    Cincinnati
    i hope dont lose any balls lololol... but i jus checked trans fluid and it was a little low so i topped it off and im actually getting some movement in second gear.. trying to upload the video
  9. #9 Re: One bad one good..
    I haven't redone one yet but will sometime in future I'm sure
  10. #10 Re: One bad one good..
    Nov 2012
    Cincinnati
    odds are im gonna drop a Craigslist trans into it.. i might just tear into this one.. or my 97 trans thats already out lol
  11. #11 Re: One bad one good..
    Nov 2012
    Cincinnati
    ok well strange enough i might as well just call it shot but im just curious if anyone can kinda name a reason as to why i was able to drive the car around the block in 2nd gear AFTER i held the rpms above 3k for at least 30 secs before it went.. it felt like it was a manual transmission, it felt like i was slowly letting off the clutch and eventually grabbed and took off but would slip in and out.. kinda feel like the TC but i have reverse with no issue
  12. #12 Re: One bad one good..
    Nov 2012
    Cincinnati
    Ok guys so i made my mind up.. im gonna attempt to rebuild it myself for a few reasons
    -save money
    -learn how it works
    -im entertained by this ish
    I don't plan on putting tons of power to it so building it up isn't an option for me..
    I plan on grabbing this video and the overhaul kit in a couple days
    Stock DVD Video Transmission Rebuild Overhaul Manual 4T65E HD 4T65E 4T65 E Trans | eBay
  13. #13 Re: One bad one good..
    gardner,mass
    These trannys really arnt that hard but if you dont have prior mechanical knowledge like rebuilding atleast an engine i wouldnt try tackling it unless you can buy yourself a jy trans and in which case you should probly just do anyway and then tear into this one and use it as a backup or throw it in once its built.
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  14. #14 Re: One bad one good..
    Nov 2012
    Cincinnati
    Honestly what I'll do.. I'm gonna just tear into this one and if its to much oh we'll ill just buy a trans.. The forward band is out anyways.. I have enough mechanical knowledge to say the least.. I'm going in confident.. But don't we all lmao
  15. #15 Re: One bad one good..
    Nov 2012
    Cincinnati
    Can someone help me pin point which rebuild kit I need from triple edge
  16. #16 Re: One bad one good..
    gardner,mass
  17. #17 Re: One bad one good..
    Nov 2012
    Cincinnati
    Ok buddy.. You just had to pick the most expensive one huh lol
  18. #18 Re: One bad one good..
    Nov 2012
    Cincinnati
    Alright so I made a trip to Pull And Pay.. Dropped the transmission pan and honestly looks clean to me..
    I need EVERYONE'S opinion..
    mileage-143k
  19. #19 Re: One bad one good..
    Nov 2012
    Cincinnati
  20. #20 Re: One bad one good..
    Looks fine to me but only 1 way to find out
  1. Key Stuck, Car Dead, and...Battery Good, Alternater good
    By izzy in forum Introductions/Noob Questions
    Last Post: 01-14-2014, 11:13 PM
  2. HID's worth it? Hi/low/fog necessary? Good brands, with good prices?
    By chamilton89 in forum Audio, Security & Visual Electronics
    Last Post: 08-06-2012, 09:10 PM
  3. Hey everyone! Good to be here!
    By 2K04GT in forum Introductions/Noob Questions
    Last Post: 07-27-2012, 12:59 PM
  4. Would this look good, really good, okish, bad, or really bad?
    By Jakescoots in forum Visual/Body Modifications
    Last Post: 02-02-2011, 06:21 PM
  5. Not good
    By starscr33m in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-25-2010, 01:35 PM
