Thread: weird! Shudder on take-off after R or N
Results 1 to 3 of 3
  1. #1 weird! Shudder on take-off after R or N
    I'm baaaaaaaaak . . . Now it's a weird take-off problem
    Took everyone's advice back in March and replaced the 4t65 in my hi-mileage 2000 GPSE.
    1st used replacement was junk. Mechanic replaced it
    2nd used replacement ok except for "THE PROBLEM" (more later) Mechanic replaced it
    3rd used replacement ok too except for "THE PROBLEM" Mechanic had it rebuilt
    3rd used replacement rebuild ok too except for "THE PROBLEM" Mechanic is presumably hiding out till I can get my hands on him monday morning.
    So what's "THE PROBLEM"?
    TRANSMISSION SLIPS & SHUDDERS LIKE CRAZY. . .
    ONLY after car is very warmed up, like after a trip to my mechanic 3 counties away, and
    ONLY on first couple of moderate take-offs, and
    ONLY after car has been in R or N.
    1-2, 2-3, 3-4 shifts are fine.
    and take off is fine as long as shifter doesn't go to R or N again.
    I am afraid to turn my mechanic loose on this one because I'm afraid something will just keep getting worse & his warranty coveage is short. I can't believe I'm having the same problem out of 3 transmissions. I'm losing patience fast & mechanic is losing hair even faster. Step right up & give me your best guess. Maybe it's not even a trans problem.
    "Nothing drives like a Pontiac" (bit I do wish it would take off right)
  2. #2 Re: weird! Shudder on take-off after R or N
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    I could easily point to a lot of trans problems that may cause this, BUT you have had 3 different transmissions in the car that do the same thing. Has the engine been thoroughly checked out and all sensors for engine and trans verified within proper working range with a scan tool? Has a pressure gauge been installed on the transmission? Has the maf sensor been check out OR you could unplug it to see what happens but of course the check engine light will come on and you will need the code cleared after reconnecting it.
  3. #3 Re: weird! Shudder on take-off after R or N
    GT Level Member GOINDEF's Avatar
    Holly, MI
    It kinda sounds like my problem that I'm having, and my issue is almost guaranteed the torque converter
  1. weird clunk
    By MikeGTP88 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-05-2009, 04:13 PM
  2. wEIrD tUNe?
    By 1badgp in forum PCM Tuning
    Last Post: 07-10-2008, 10:08 AM
  3. Weird shifting problems
    By Sick03L in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-09-2008, 07:48 PM
  4. weird noise
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-30-2008, 04:17 PM
  5. Forums Acting Weird
    By 19SE92 in forum Forum Bugs/Suggestions
    Last Post: 02-29-2008, 08:03 AM
