Thread: trasmission qustion
Results 1 to 9 of 9
  1. #1 trasmission qustion
    May 2011
    ohio
    just a quick question guys. should i get a transmission flush on my grand prix?
  2. #2 Re: trasmission qustion
    Charles City, IA
    If the fluid is burnt and all your clutch materiel is not in the pan yes.
    SMGPFC Two Nipple General
  3. #3 Re: trasmission qustion
    without any info or anything.
    Maybe
  4. #4 Re: trasmission qustion
    no flush, just drop the pan and change the filter, then refill with 7-8 quarts of dexron 3.
  5. #5 Re: trasmission qustion
    May 2011
    ohio
    thanks guys for the info
  6. #6 Re: trasmission qustion
    May 2011
    ohio
    what about useing z max as a additive
  7. #7 Re: trasmission qustion
    GrandPrix Junkie
    St. Louis
    Wouldn't bother with that stuff. If you really want an additive throw some Lucas in it.
  8. #8 Re: trasmission qustion
    Z max engine treatment has the same stuff in both bottles as per the rep...
    Just to give you an idea of the kind of "fun" they have in advertising.
  9. #9 Re: trasmission qustion
    GT Level Member torq455's Avatar
    Dec 2008
    Alabama
    The red bottle of Lube Guard is good stuff.
    2002 GTP: K&N, 3.2 pulley, flipped mounts. ZZP SS headers, 180 stat, NGK TR6's, MSD wires, Reptile ported TB, ported S/C, ported LIM, Intense Stage II heads with larger Manley severe duty SS valves, Yella Terra 1.9 full roller rockers, LS6 springs, Racetronix fuel pump re-wire, Oil pressure "kit", JMB FWI. Mustang dynoed at 240 WHP, 272 WTQ.
