Complaint: Transmission grinding sound under Deceleration. Eventually lost all gears. Can shut the car off and let cool for about 2 minutes, restart and regain gears, however, shortly after, car loses gearing again and grinding sound comes back. When I restart the car after it has been sitting, if I raise the rpm you can hear the noise best. Idle in gear is quiter.
Cause: ? unknown....could have been due to low oil level after changing axel, but loss of oil was approx 1 qt. checked dipstick and was still showing fluid after replacement of axel. Could this be a torque converter problem?
Any help or thoughts would be appreciated.
