Thread: 98 GTP Trans Swap What years are compatable
Results 1 to 5 of 5
  1. #1 98 GTP Trans Swap What years are compatable
    West Palm Beach, Florida
    hey there...i think the title pretty much says it all. What Years, makes, and model will work for it?
    i know the regal, Bonneville, and grand prix all use the S/C v6 (l67) engine, but what years and models use the same trans that we could just pull out and put in the 98 gtp any help would be appreciated thanks!
  2. #2 Re: 98 GTP Trans Swap What years are compatable
    St. Louis
    Anything from 98-02 will work from a GP. As long as its from a GTP as the gear ratios are different in the N/A cars. Not sure on the other cars.
  3. #3 Re: 98 GTP Trans Swap What years are compatable
    i went to a dealership, and he told me that the 99s differ from the 98? has anyone really done it who could shed some insight?
  4. #4 Re: 98 GTP Trans Swap What years are compatable
    trans lines may be a slighty different, but thats not a big deal.
  5. #5 Re: 98 GTP Trans Swap What years are compatable
    St. Louis
    Ah, yes, duh! Forgot to mention that. Yes, the trans. will have a different style fitting on the inlet side of the transmission. The end at the rad. is the same but GM changed the design where it goes into the trans.
    This requires you to use a 98-99 threaded end style cooler line that connects to the transmission as the 00+ case has a different thread size for the feed line that wont work in a 98 case. You could swap fittings on the return line, which is the smaller of the two fittings, and use your stock cooler line.
  1. Trans swap ???
    By cogsracing in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-28-2011, 12:40 PM
  2. Trans Swap
    By Terry102 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-25-2011, 08:38 PM
  3. trans swap
    By GOINDEF in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-03-2011, 01:13 PM
  4. Torque Update - Now 1.5 and 1.6 compatable!
    By BwolfGT in forum Off Topic Discussion
    Last Post: 06-22-2010, 08:43 PM
  5. Trans/PCM swap
    Last Post: 10-06-2009, 09:13 PM
