Thread: Mr Trannyman, I need your advice
Results 1 to 4 of 4
  1. #1 Mr Trannyman, I need your advice
    GT Level Member t24moore's Avatar
    Feb 2008
    Houston
    Okay, I found a donor car to put my valvetrain in. Its a 2002 GP GT. Now my current transmission is a stock GTP unit with a shift kit. I was wondering if it was alright to use the GT transmission seeing as it already has the gearing that I want. My plan is to refresh it and put in some hardened parts. Or should I keep my GTP trans and refresh that with new gearing? Please give me some words of wisdom, thanks alot.
    Comp Turbo 6765 T4-ST5-A2A IC-Ported Heads-Custom Turbo headers-80 lb inj-F-Body UIM and LIM-AEM WB, TEP trans w 1" chain and Circle D TC, Dual 255s, Bilstien Struts
    WHY IS EVERYONE SO OPPOSED TO DOING A COMPRESSION TEST TO TROUBLESHOOT PROBLEMS?
  2. #2 Re: Mr Trannyman, I need your advice
    Barksdale AFB, LA
    I'd say go with the younger trans. The only differences are the torque converter size and the differential.
    2009 Subaru Impreza WRX STI
  3. #3 Re: Mr Trannyman, I need your advice
    Donating Users Tengis's Avatar
    Houston
    I forgot about that... might be nice for him to have the higher stall converter. We could easily swap the diff from his other car if it looks good when we take it out, so thats no big deal.
    Silver R32 Skyline GTS-T
    Satin Purple 97 GTP
    Blue 01 IS4 + M112 hybrid GTP
    Satin Black 98 Turbo GTP
    ZZP recommended installer - Kratos Concepts
  4. #4 Re: Mr Trannyman, I need your advice
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    Either way it isnt really going to matter much if you plan to go through the GT trans. As mentioned above other than the gear the differential and converter are really the only main differences between the two and all other internals are the same. If the GT trans looks to be in better shape then I would use it and go ahead with your plans to upgrade it.
  1. need info/advice
    By Quicksilver_GP in forum Off Topic Discussion
    Last Post: 05-28-2008, 11:24 PM
  2. exhaust advice
    By Scott B in forum General Tech Discussion
    Last Post: 05-28-2008, 09:45 PM
  3. Trannyman...need your advice...
    By VerzGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-30-2008, 07:52 AM
  4. Mod advice from those w/o mods
    By IndeedSS in forum The Rant Forum
    Last Post: 03-09-2008, 08:26 PM
  5. Need Advice on 97 GTP
    By GreenNirvana101 in forum Off Topic Discussion
    Last Post: 03-02-2008, 12:46 AM
