Thread: fml tranny problems. slow shifts;no 4th.
Results 1 to 10 of 10
  1. #1 fml tranny problems. slow shifts;no 4th.
    GT Level Member MrPhotographer06's Avatar
    Fort Bragg, NC
    So, I just rebuilt the top end in my motor. About 5 or 6k before the rebuild, the trans would start whining, and shift hard. If I pulled over and cut the car off, it would stop. Since the intial start up date, a week ago( last Sunday) its had these problems.
    Day 1: hanging in 2-3 shift long.. instead of going into third, it slowly shifts unless yo kind of let off and feather the gas. Also did the whining thing once.
    day 2-(Mon) same.
    3-6 fine.
    7( sat) did the whining thing again, twice, _then went away.
    8( Sunday/ today) it did the whining thing, but I didn't have a place to pull over. I was 15 Minutes from my fiancé's house, so I just kept going. After about 2 miles and 2 stoplights I realized when I let off the gas, I was dropikg to idle. It wasn't till I left there tonight, that it seems as I've lost 4 th. Any suggestions?
    How hard is a Tranny swap?
    Thanks, Scott
    2001 Grand Prix GT
    3800,Open Cone, Tinted tails, 5% front tint, double 5% rears. Kenwood head unit, new subs-pending
  2. #2 Re: fml tranny problems
    Fort Bragg, NC
    Drove it this morning, And it still wont go into 4th. Its also slow shifting in the 1-2 and 2-3 shift. A couple posts said something about pressure sensor? And filter change. I haven't changed the trans filter because of the scare to burn it up. A lot of cars weaken when you change the fluid and filter, so I was scared to. Reckon its too late now.
    Thoughts?
    2001 Grand Prix GT
  3. #3 Re: fml tranny problems. slow shifts;no 4th.
    Mercer, Pa
    4th gear splined shaft strips at higher mileage on pre 2003 transmissions. Visit http://www.tripleedgeperformance.com/ and there are throuble shooting guides for the transmissions. I bought all my parts to rebuild the tranny from him.
  4. #4 Re: fml tranny problems. slow shifts;no 4th.
    Fort Bragg, NC
    What did it cost you?
    2001 Grand Prix GT
  5. #5 Re: fml tranny problems. slow shifts;no 4th.
    Scott... no trans dies from a bit of maintenance. Transmission fluid is similar to motor oil in that it's an oil with detergents etc in it and there's a filter.
    Whining is caused by the pump not being able to pull enough fluid through the clogged filter. I'd suggest starting off with dropping the pan and changing the filter. Put in a bottle of Lucas stop slip and top it off with fluid. Then drive about 100 miles before making any more determinations on how good/bad it is. Meaning, give the detergents and additives in Lucas to work.
    Then if you still lack fourth, it's most likely the hub shaft. That's not too bad to swap if your willing to do some work.
  6. #6 Re: fml tranny problems. slow shifts;no 4th.
    Fort Bragg, NC
    I have no problem with the work, I just did the top end rebuild, and after that back manifold and head, I think I can conquer the world. lol. Ill start on the filter and fluid..whats the Hub replacement require?
    2001 Grand Prix GT
  7. #7 Re: fml tranny problems. slow shifts;no 4th.
    You didn't ask about a hub replacement. lol.....
    34mm socket if axle was replaced, 35mm if it's stock (most guys use a 36mm and call it good)
    1/2" socket for the bolts, although a 13mm fits..it's sloppy. If things go bad, you want a 1/2" ..and six point only. Then add in a 15mm for the caliper bracket bolts and 19mm to get the tires off.
    Trans service is jack or ramps and 20 bolts. A large Steralite container from (18" x36" x 6") is great for catching the fluid.
    On teh trans.. reuse the gasket if it's the metal inlaid stocker, and torque is 120 inch lbs aka 10 ft lbs
  8. #8 Re: fml tranny problems. slow shifts;no 4th.
    St. Louis
    Maybe he meant the 4th clutch hub?
  9. #9 Re: fml tranny problems. slow shifts;no 4th.
    I dunno.. not really enough info .. I went with wheel hub
  10. #10 Re: fml tranny problems. slow shifts;no 4th.
    Fort Bragg, NC
    You said could be the hub shaft , if I was willing to do a little work. Haha that's what Iwanted to know. How hard is it?
    2001 Grand Prix GT
  1. 07 with tranny problems?
    By nwulf1 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-06-2009, 05:43 PM
  2. Tranny problems need help
    By gtryda in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-06-2009, 03:31 PM
  3. 98 GTP tranny problems
    By pontiacGTP123 in forum General Tech Discussion
    Last Post: 05-20-2009, 07:29 PM
  4. tranny problems
    By krippled in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-04-2009, 01:35 PM
  5. New Tranny Problems..
    By NMillis in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-30-2008, 06:24 PM
