Thread: Opinions on Dex 6...
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 62
  1. #1 Opinions on Dex 6...
    Pennsylvania
    Im on the stock 4t65e, just a couple hundred over 50k and Im gunna drain and replace my fluid and filter... checked the fluid yesterday and it's just a little bit darker and doesnt smell burnt, good level, seems in good shape.
    Question is, I've heard some people say bad things about the dex 6.. slipping and weird shifts and other stuff..
    I've also read that it's only a problem with older transmissions with more wear and tear, or transmissions that havnt been taken care of.
    What are your opinions, think I'll be ok with it since my tranny is relatively young and in good shape? Think it'll be a bad move?
    Anybody have good experiences with it?
  2. #2 Re: Opinions on Dex 6...
    Florida
    From what ive read the older your car is the more likely you want to stick to dex3. I have an 01 and just did my shift kit and replaced with dex3 no probs at all, id say do that to avoid probs. But if your car is newer then I dont see why not.
  3. #3 Re: Opinions on Dex 6...
    I know of many guys even 4T60's using Dex 6 and reporting better shifts and cooler temps. Seems good. Walmart has a good priced in house brand of it that most are using and like.
  4. #4 Re: Opinions on Dex 6...
    I live here. TLSheff's Avatar
    Replaced Fluid and Filter about 8k ago on my 99 GTP 4t65hd and used GM Dex6. Shifts seem a little more solid than before, but the tech said it was pretty dark and a little burned. I doubt if the previous owner ever did a change and i had it done at 80k miles, but its holding strong, cant say anything on temps tho
  5. #5 Re: Opinions on Dex 6...
    Banned
    Sioux Falls, SD
    The Dex 6 is great to use in the newer GP's 04+. But when you have the olderGP's you might want to be careful, Dex 6 is full synthetic and dex 3 is not. The dex 6 might cause the older style trans to slip.
  6. #6 Re: Opinions on Dex 6...
    Donating Users BoostnBlackGTP's Avatar
    Waterloo, Iowa
    yes dex 6 is perfect for 04+ grand prix's but in the 97-03 grand prix's dex 6 is thinner than dex 3 and that causes them to slip and not shift perfect in WOT. so i recommend to get dex 3 in a 97-03 and dex 6 in 04+
  7. #7 Re: Opinions on Dex 6...
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    I replaced my 03 GTP 4T65E-HD fluid and filter with GM Dex 6, about a 1.25 years ago. No problems with it.
  8. #8 Re: Opinions on Dex 6...
    SE Level Member Beast388's Avatar
    Jul 2010
    Iowa
    I have replaced Dex 3 with Dex 6 in both my '04 Trailblazer and '01 GPGT. If you read what GM states about Dex 6, they say it is completely backwards compatible.
    In both cases, the transmissions operated smoothly and flawlessly after the switch.
    On the GP, I installed a Transgo shift kit as well to eliminate the Max-Adapt shift problem that plagues the 4T65e......no more hard shift and nice, smooth performance.
    2001 Grand Prix GT - Dark Bronzemist Metallic
  9. #9 Re: Opinions on Dex 6...
    Lookup the viscosity numbers.
    its about half as viscous.
    This can be bad for the older transmissions that prefer the thicker stuff.
  10. #10 Re: Opinions on Dex 6...
    Idk my tranny seems to like the Dex 6 more than the Dex 3, when I first got this car in February of last year, I dropped the pan and changed the filter fluid and put in Dex 3 and it turned black after 3 or 4 months so I dropped the pan again changed the filter again and added Dex 6 instead the fluid is still nice and red and the car shifts a lot better than it did with the Dex 3.
  11. #11 Re: Opinions on Dex 6...
    Pennsylvania
    Thanks everyone, that info helped a lot, gunna go and do it on wednesday I think, just cause I wont have time till then.
    Advance Auto has a sale going on, 3.99 a quart for any castrol ATF so go stock up
    Turned a 60 dollar project into a 40 dollar one.
  12. #12 Re: Opinions on Dex 6...
    Look for a synthetic dex III.
  13. #13 Re: Opinions on Dex 6...
    Dec 2010
    Canada
    Noteworthy is that Dex 6 viscosity is allegedly much more stable with number of test cycles, compared to Dex 3. Viscosity of Dex 3 will be higher than Dex 6 initially, but not after many heat cycles.
    Probably have slightly lower trans temps with Dex 6.
  14. #14 Re: Opinions on Dex 6...
    hence the twice as long replacement interval.
    if you used a synthetic dex III i can't see it being much different.
  15. #15 Re: Opinions on Dex 6...
    Donating Users moddman's Avatar
    Midwest
    Quote Originally Posted by That Canadian Guy View Post
    Amsoil ATF is a good synthetic D3 to use.
    3.4" ZZP MPS Pull
    ey,ZZP Coupler,NGK PLUGS,L67 Coils,INTENSE 1.8 RR, Custom PCM Tune, ZZP Stage 2 IC, 180* T-Stat, 42LB RE-FLWD Inj.
  16. #16 Re: Opinions on Dex 6...
    Midwest
    Quote Originally Posted by mechguy View Post
    X2 I just had my fluid changed to D6..my trans. temp gauge barely moves.
    3.4" ZZP MPS Pull
  17. #17 Re: Opinions on Dex 6...
    Missouri
    Is there a point where you should not change the tranny fluid because it causes slips and can hurt the tranny? I thought I read that somewhere. Just wondering because I have around 93k miles and I don't know if its ever been done. Should I change or no?
    SMGPFC Member #7.5
  18. #18 Re: Opinions on Dex 6...
    Midwest
    "GM states about Dex 6, they say it is completely backwards compatible."
    Enough said......
    3.4" ZZP MPS Pull
  19. #19 Re: Opinions on Dex 6...
    Midwest
    Should I change or no?[/QUOTE]
    It would be good to drop the pan, change the filter with a GM/SPX original USA made filter, and use synthetic D3 or D6 fluid. I used valvoline synthetic D6 and am happy with the outcome.
    3.4" ZZP MPS Pull
  20. #20 Re: Opinions on Dex 6...
    Pennsylvania
    Well...
    GM's done and said a lot of things they were 100% sure was true and best..
    then later went back and revised what they said and did
  1. Is this really that bad? Need opinions
    By SilvaMan61 in forum General Tech Discussion
    Last Post: 08-24-2010, 05:29 PM
  2. Need Opinions
    By BwolfGT in forum Off Topic Discussion
    Last Post: 03-28-2010, 09:53 AM
  3. opinions
    By TorqueAutoMotiv in forum Tires & Wheels
    Last Post: 03-26-2010, 12:25 PM
  4. What you think about this GTP, please opinions
    By robahr24 in forum Off Topic Discussion
    Last Post: 02-06-2009, 12:34 PM
  5. Opinions of my Gp Gt
    By gpracing in forum General Tech Discussion
    Last Post: 09-18-2008, 11:22 PM
